Old 02-02-2021, 07:14 PM
10xhobby 10xhobby is offline
Default 70 Trans Am correct finish for control arms
Could someone send some pictures of the correct restoration and finish of the upper and lower control arms with the raw metal ends by the ball joints for my Trans Am
Old 02-02-2021, 08:51 PM
Formulabruce's Avatar
This is "Adrian" a 1972, but same paint etc. Originally the paint was a cheap gloss ( 90%) black alkyd enamel, just to keep the rust off. This paint was NOT very durable, and most anything today is far superior.
Old 02-03-2021, 12:23 AM
Transamric's Avatar
Certainly can't show up "Adrian", but here's my attempt to match the original finishes I found on this 45K mile Esprit. I cleared the bare metal ends with a polyurethane satin to keep the rust at bay.
Name:	72 Esprit LF #15.jpg
ID:	560028   Click image for larger version
Name:	72 Esprit LF brake #2.jpg
ID:	560029   Click image for larger version
Name:	72 Esprit LF brake #10.jpg
The Following User Says Thank You to Transamric For This Useful Post:
Old 02-03-2021, 02:52 AM
Does anyone know where I could my replacement upper ball joints riveted on like they were done at the factory?
Old 02-03-2021, 03:56 AM
I believe you can buy the fake rivets from Ames. Rivet on top, and nut goes on underside.
Problem solved.. and its DIY !
Old 02-03-2021, 09:06 AM
Aus78Formula Aus78Formula is offline
Looks good. But processed bare steel is always a lot greyer than sandblasted and stripped steel, or painted to match.
The Following User Says Thank You to Aus78Formula For This Useful Post:
Old 02-03-2021, 03:34 PM
Transamric's Avatar
And camera flash makes bare clean bare steel appear to be much brighter and whiter than when seen in person.
Old 02-03-2021, 08:56 PM
Absolutely. Compare the close-up and distant pics with flash.
