Tri-Power Tech 57-66 Tri-Power Talk
Old 07-26-2023, 08:26 PM
Default Big car throttle rod
Can anyone post a picture of how the throttle rod on a 1964 big car attaches to the arm on the center carb. 1961-1964 should be similar. Thanks
Old 07-27-2023, 05:38 AM
Kenth's Avatar
Kenth Kenth is offline
This:
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 07-28-2023, 07:52 PM
Thanks for the Thumbnail but when I click on it it's all blurry.
Old 07-28-2023, 08:14 PM
jamesq's Avatar
jamesq jamesq is offline
This is the setup for my 63 Bonne wagon that I have ready to install.
I hope this is helpful, let me know if you need any other views.
James Q
ID:	616923   Click image for larger version
James Quayhagen
1963 Bonneville Safari - Nocturne Blue, 4-speed
Old 07-29-2023, 01:43 AM
gtoguys gtoguys is offline
Is your car an automatic or a manual? If it's an auto, you will need a ball stud at the bottom of the throttle arm.
Old 07-29-2023, 10:08 PM
I have everything now but the throttle stud does not seem to be the correct length. Could you measure the distance from the arm on the carb to the end of the ball stud. thanks.
Old 07-30-2023, 12:23 PM
jamesq's Avatar
The ball stud for the accelerator throttle rod is 1" from the carb arm.
This is a manual trans set up.
James Q
James Quayhagen
Old 07-30-2023, 02:31 PM
pfilean's Avatar
pfilean pfilean is offline
Pivot mechanism on firewall are 61 then change in 62 and I believe change again for 63-64. Rods are similar but lengths probably different with each change. The 61 and I think 62 each had return spring as part of the firewall mechanism. Later had a long return spring from carb lever to a bracket mounted to a manifold bolt so that could result in different rods also.
Old 07-30-2023, 06:30 PM
Oh good. I have a 1964 Tripower engine in a 1962 car. I guess I have to experiment. Thanks.
Old 07-31-2023, 10:05 AM
pfilean's Avatar
Maybe this will help. 64 carbs, 61 manifold, 61 linkage on firewall. A couple of these were when I had the later style progressive linkage and a couple were after I put on proper 61 fuel pipe and the early style progressive linkage.
ID:	617090   Click image for larger version
ID:	617091   Click image for larger version
ID:	617092   Click image for larger version
