Old 10-16-2019, 05:37 PM
tom s tom s is offline
Those are the old Comp lifters,no clue who made them for them.I have a set in a running driving engine right now.Have been if for a few years.Tom
  #62
Old 10-16-2019, 06:16 PM
AG's Avatar
AG AG is offline
Originally Posted by shaker455 View Post
Dan has not moved yet?
Not until next fall.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
  #63
Old 10-16-2019, 06:19 PM
AG's Avatar
AG AG is offline
Originally Posted by nmoreilly View Post
Very similar to the issue I had. Just curious what your cam specs ?- assume they are the ones in your tag line
OF HR. 236/245 at 0.050", 0.627/0.632" lift with 1.65 rockers.
  #64
Old 10-16-2019, 06:57 PM
OK,here is another maker of hyd roller lifters that are sold to cam companys.Anyone know about them?
https://www.gatermanproducts.com/
  #65
Old 10-16-2019, 08:06 PM
nmoreilly nmoreilly is offline
Thanks mine is 253/255 at 0.050, 0.640/0.640 lift w/1.65
  #66
Old 10-16-2019, 08:23 PM
Formulajones's Avatar
For interest, the hydraulic roller we had the old Morel Comp Cam roller lifters on 15 years ago was 254/262 @ .050 and .628" lift. Ran perfectly quiet.
  #67
Old 10-17-2019, 08:56 AM
Thanks, interesting
  #68
Old 10-17-2019, 10:20 AM
So, I bought these used for a year lifters. Had them for several years myself just sitting for a future build.
They have the snap ring. They all seem to be in good shape.
What is the chance they are the failure prone ones ? Looks like a crapshoot to me. Has Comp always used offshore parts ? Some have had success with these.
Those are the same lifters I posted a picture of in #53 (on the left)
We used them 15 years ago on a 254/262 @ .050 cam in a 455 and ran that engine for about 5 years. Nothing wrong with them. Keeping them around for another build in the future.
  #69
Old 10-17-2019, 10:58 AM
Same ones I have in a 455 I built back in April 2017.In my 69 bird,drive it every week with no issue.I think because all these lifters are assm by human beings we are all open to mistakes.So far so good with all of mine.Tom
  #70
Old 10-17-2019, 11:04 AM
Yep, seems the biggest issue from everything I'm reading is the internal leak rate varies. Some are quiet, some not so much.
Those old ones in my picture were whisper quiet in a 455, and didn't have the lifter bore mod either. They never ticked or made any noises and looked perfect when they cam out 5 years later. Oil band is clearly not in the right location but didn't seem to matter, even on the 254/262 @ .050 cam with .628 lift.
The new ones on the right are now in dad's 571 MR1 block. Correct oil band location on those, and are the Shavers. These are also nice and quiet on a pretty big custom hydraulic roller.
  #71
Old 10-17-2019, 12:47 PM
Te one thing that seems common is the inconsistency which suggest a QC issue
  #72
Old 10-17-2019, 01:56 PM
Cliff R's Avatar
Cliff R Cliff R is offline
"Yep, seems the biggest issue from everything I'm reading is the internal leak rate varies. Some are quiet, some not so much."
These are excellent quality but cost considerably more......Cliff
https://www.summitracing.com/parts/c...w/make/pontiac
  #73
Old 10-17-2019, 04:34 PM
Nice. I wouldn't be afraid to try a set of those.
  #74
Old 10-17-2019, 05:34 PM
blueghoast's Avatar
blueghoast blueghoast is online now
I won't use comp lifters at all any more.
Bought a set 20 years ago and had nothing but problems with.
I've heard nothing but bad about comp hyd-lifters sence I had my problem
with them. I like there cams though.
GT.
  #75
Old 10-17-2019, 06:17 PM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
Me too. If you shop around you can find the Crane hr’s for a bit less than Summits’ list price.
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
  #76
Old 10-17-2019, 07:09 PM
64speed's Avatar
64speed 64speed is offline
Is anyone running the Lunati or am I the lone wolf?
  #77
Old 10-17-2019, 08:38 PM
You used have a solid roller that in that motor ?
  #78
Old 10-18-2019, 05:53 AM
Cliff R's Avatar
I've only used the Crane HR's twice and both of those engines are dead quiet cold, warm or fully warmed up and heat soaked. They also showed no indications whatsoever of having any sort of high RPM issues on the dyno.
Every single set of Comp HR's or any set of Morel lifters have had at least one "ticker" in the bunch whether cold, fully warmed up, or all the time. I also found that I had to set them with the plungers bottomed out then back up 1/2 turn vs going to zero lash and down 1/2 turn or so. This doesn't give them much room to make noise and reduces customer complaints, but what we are really doing is to "crutch" a fix vs simply using a par that's built to a higher standard in the first place.
I've talked to numerous other engine builders and they have the same issues with Morel HR's. They are inconsistent on plunger to body clearances so the leak down rates are all over the Map.
I've also noticed numerous changes to the HR's over the years. This includes plunger travel and how stiff the spring is under the plunger.
Just heard the other day from a pretty good source that Isky will make HR's for Pontiac engines with bushed rollers. They are custom made and $1200 per set.......Cliff
  #79
Old 10-18-2019, 06:46 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
The old half turn adjustment approach doesn't work on Comp Cams 857 lifters. I tried a few adjustments and 1-1/4 worked best. Which is consistent with the INSTRUCTIONS. Lifters require .050"-.100" preload (7/16-20 thread = .050"/turn).
Name:	Comp Cams Lifter Adj.PNG
ID:	522391   Click image for larger version
Name:	Comp Cams Lifter Adj 2.PNG
  #80
Old 10-18-2019, 07:14 AM
The 1/2 turn method will have various lifter preload settings depending on which stud you're using, so have to pay attention to that.
Since most Pontiac guys here (least I hope so) run the big block chevy 7/16 stud which is 20 threads per inch.
1/2 turn on this stud will only give you .025" preload on the lifter. Generally lifters require a pinch more preload than that if you read instructions, but each lifter is different. In most cases .030 to .050" is what I see with the paperwork provided.
