Old 06-01-2020, 04:13 PM
topfuel67 topfuel67 is offline
Default 1966 GTO Tripower Venturi cluster numbers
Does anyone have the correct Venturi cluster numbers for the center and end carbs for a 66 GTO? I tore apart several carbs over the years and didn't label the Venturi.
I have a 38864,2- 16266 that only have 2 tubes and 3- 16266 that have 4 tubes. I have a couple of others, but I'm pretty sure they're for early 60s or late 50's small Rochesters.
Thanks in advance.
Old 06-01-2020, 04:41 PM
Dick Boneske's Avatar
The ones with the two tubes are for the end carbs. They have cast numbers 16266 on them
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 06-01-2020, 05:12 PM
Is the 16266 with 4 tubes for the center?
Thank you
Old 06-01-2020, 07:52 PM
DavesGTO's Avatar
DavesGTO DavesGTO is offline
Not sure if this helps but about halfway down the float bowl parts list
Old 06-01-2020, 11:47 PM
The clusters have casting numbers on them, not the part numbers shown. Thanks for the effort, regardless. I checked and found the following cluster numbers for center carbs. I believe 16266 is a correct number--if it's one with four tubes on it. I also found 31305, 15598, and 26958 on some other large Rochester 2 bbls.
Any of these will work if they have the proper sized idle tubes, idle bypass restrictors, and idle vents. Stock idle tubes for a 389 would be .033", idle bypass .043", and idle vents at about .039". None of these numbers are OK if you're running a lumpy cam.
BONESTOCK GOATS
Old 06-02-2020, 03:47 AM
Thank you all for your replies. I'll measure the tubes to be sure. I'm going with the factory cam and factory specs.
Old 06-07-2020, 05:22 PM
The clusters that have the same physical configuration all are the same functionally except for idle tube sizes, idle bypass restrictor sizes, and idle vents.
The later ones--about 1968 and up, have an extra equalizing channel below the cluster, which is not covered with gasket unless you use the proper cluster.
BONESTOCK GOATS
Old 06-15-2020, 08:52 PM
What do the numbers stamped in the corner stand for? Some have a 70, some have 72, some have 68 etc. Is this related to the jet size? Even though it seems most of the factory jets are 55 - 68 range. I haven't really seen too many factory jets 70 and above in the carbs I'm playing with and a lot of these clusters have 70 or 72 stamped. Over the last few years I've acquired about 20 Rochester 2G carbs. Some just plain old 2bbl and some tripowers.
Donald
