Tri-Power Tech 57-66 Tri-Power Talk
Old 05-30-2020, 04:13 AM
ponchorob ponchorob is offline
Default Tripower jets where can i buy them
Need 68 to 69 jets for 65 tripower Who offer a jet kit...
Old 05-30-2020, 11:15 AM
GTO 68's Avatar
GTO 68 GTO 68 is offline
Try contacting John at Pontiactripower.com. His website has sales and service for all the items that you need. John runs an ad in the GTOAA newsletter every month. His knowledge is amazing. I have used his service for several years.
Old 05-30-2020, 04:57 PM
Thanks for advice and info...
Old 05-31-2020, 03:04 PM
Dick Boneske's Avatar
PM me. I have hundreds of .068" jets. They were standard on nearly all Pontiac Tri-Powers since 1959 in the end carbs. I change them to .070" or .073" jets in nearly every restoration I do, so have many on hand. I can send some if you describe your need.
I would suggest you put .070" jets in your end carbs, even if the engine is relatively stock. Center carb seems to like .063" for near stock applications.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 05-31-2020, 05:43 PM
Hi...my combo 62 catalina 65 421 engine with 64 tripower slightly modified heads with 1.94 intake valve and a crane ramair 4 cam...10.5 compression....,rear end is 2.87..... i know the cam is too big for the combo but i bought the car as it is....so i need a good jetting advice....
