Tri-Power Tech 57-66 Tri-Power Talk
Old 07-10-2020, 08:04 PM
footjoy's Avatar
footjoy footjoy is offline
Default Tri Power fuel pressure
What is the correct fuel pressure for the rochester center carb on a 65 setup?
Greg
Old 07-10-2020, 08:16 PM
Tom Vaught's Avatar
Boost Engineer
5.5 psi is a good pressure to run on all three carbs.
Higher pressure pumps do nothing for you if you do not have the correct fuel inlets, correct fuel line size from the tank, and a fuel tank pick-up that does not allow the fuel to run away from the pick-up.
Tom V.
