#121
I'm going to have the 3", Borla Pro XS on my setup soon. I'll report back as these don't get as much attention but they make the most power with a slightly lower decibel sound.
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Intake & Rails, PTC 10" 0 Stat, Ricks Hot Rod SS Gas Tank, Magna 4303, Aerom EFI Reg, Aerospace Front & Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, Powersteering.com Pump & 12:1 Box, QA1 Front Arms & Viking Berz CO + Rear Shocks, Hella UP28 Vac Pump |
The Following User Says Thank You to GOAT8U2 For This Useful Post: | ||
#122
Extra power v drone
I'll give up a tiny bit of power to eliminate risk of drone every time!! Any "straight through" style like Borla or Ultraflow versus a "turbo" chambered muffler like Dynomax Super Turbos risks drone. I recently learned that the Super Turbos were named after a new muffler design in the 60's for the turbo Corvair that had a drone issue in testing....
1974 Lemans Sportecoupe GT (daily driver) "Well the girls out there knock me out, you know Cruisin' around in my GTO" Rock 'n' Roll High School Ramones |
#123
We've went over the droning issues in several threads in the past.
The straight through designs from my experience are actually better at controlling any drone. The only mufflers I've had droning with are chamber style mufflers. In fact I've mentioned in the past it's more related to how the system is hung on the car. As many use the cheap auto store hangers or what ever is supplied in the exhaust kit. Which actually mounts the system very solid to the car. I prefer to use the factory hangers for the particular car I'm working on, and most all that stuff is reproduced today. You might pay $100 or more for the correct hangers, but the OEM designed hangers do a much better job of isolating the exhaust system from the car. I'm running Dynomax Ultraflows on 2 other cars here, both with "X" cross overs and neither car exhibits any drone what so ever. Both have long tube headers and one of them is a complete 3" system, the other 2 1/2" |
The Following User Says Thank You to Formulajones For This Useful Post: | ||
#124
Same experience here. We’ve got 3” to the X 2.5 out with long Ultraflows on the wife’s convert. No drone. I used a Torque Tech system. The hangers were much better than parts store stuff. I think that makes a big difference. Sadly, I think Torque Tech is no more. He was a great help to me in deciding on a system. Murf Sent from my iPhone using Tapatalk Pro |
#125
I bought my Dynomax Ultraflows from 4wheelonline this year. I like the sound of this muffler. Not too loud, and no drone at all. It has a nice rumble at idle.
#127
Exhaust Cut outs
What do you guys think of adding electric exhaust cut outs on my 77 with shorty headers Pypes H system and super turbos.
#128
We have cutouts on 3 of the vehicles here and 2 of them are electric. Probably been using them off and on for 16-17 years??
I like them for a few different reasons. It's really up to you and what your intentions are. |
#129
I just want to make noise now and then.
#130
It's good for that
It makes a great second horn. Or when some guy pulls along side and revs the engine, flip the switch. Another reason I run them is to play with them at the track to see if it's worth anything. It's especially worth while if you run a small quiet system on the car that might be a pinch restrictive. Easy back to back comparisons. And while I do like racing the cars through the mufflers for a real street ET, the old school in me still loves to hear a car with open headers going down track. They seem to work best if placed beyond the header collectors at least a foot or more but that all depends on the car and the room you have to work with. https://youtu.be/M-TsdxjE144 https://youtu.be/HQ7e9o4qAaI |
#131
Now that I think of it, 3 cars here have electric cutouts.
I use DMH on the Chevelle and they've been great for more than 16 years or so. They are the larger 3 inch round units, and this car had the room where I could extend some 3" pipe up and out of the way so they can't even be seen. For more ground clearance on tighter applications I like the low profile oval cutouts from Quick Time. I'm running those on the other 2 cars because they were a little tight for room, and they are easier to tuck up under the car. They all do an excellent job of sealing up, no leaks or ticking of any kind from them. |
#133
Sent from my SM-G981V using Tapatalk
************************************* 1968 Lemans. 37,000 original miles. GTO clone. 462ci/KRE 290 heads. UltraDyne 280/288 Solid/850 Qjet by Cliff/Performer RPM/TSP 9.5" in TH400/8.5" 3.42 gears/3950# Race weight/12.58@106 at Bandimere speedway high altitude |
#135
They are worth some ET and MPH, but it varies from car to car. Depends on how good the exhaust system is to begin with, what the engine likes, and where the cutouts are placed.
I've found they work best if you move them at least a foot or more away from the header collectors, similar to the affect you get with open headers that show gains with a collector extension. Just works better if it's down stream a bit and designed with a straight shot if there is room to do that. I might have some pictures here somewhere. I should probably video the comparisons with the go pro next time at the track. |
Thread Tools | |
Display Modes | |
