70 T/A Which Brake System?
Progressing with the complete restoration of my 70 T/A and need to decide on Brakes. The car has the correct and original 3, brake valve components (Proportioning valve, hold off valve and ? valve ) that mount under the M/C. Since I never drove the car B4 the tear down I have no idea if these 3 components function properly or not. I understand they are not available reproduction or otherwise. One option is to replace the Booster and MC and put it together and hope those 3 items work ok. Or, I can go with the 1971 and up system which only uses the proportioning valve and not the other two items. I realize using the 1971 system is not correct in appearance but it would be sure to work properly as it would all be new. Any thought or advice on what I should do w/o breaking the bank? Thanks
1970 T/A |
I had the same though on my 70 car . I went with the Welwood disc system . But in making the decision of what to do .I found that all the components are available including the brake lines . Inline Tube and The Rite Stuff have the components except the delay valve . That is the valve that causes a slight delay in pressure to rear brakes . This was meant to stop premature rear brake lock up.
I did not do it but I understand that all three valves can be taken apart and cleaned and put back in service. |
Does anyone know a service that can repair the 3 valves or is there a service manual on this? Thanks
1970 T/A |
Whitepost in Virginia does a great job. They have done several MC’s for me and also did the prop valve on the Black Car. Great work and quick turnaround.
https://whitepost.com/#hometop |
Thanks Bob, I will give them a call. Dave
1970 T/A |
second on the white post
http://gloryrestoparts.20megsfree.com/ 1970.5 Pontiac Tempest GT-37 400ci 4bbl 4sp 3.90:1 12.73 @ 112.42 2011 Pure Stock Drags 12.71 @ 110.58 2013 Martin FAST/FS race 12.70 @ 111.74 2014 Pure Stock Drags 12.60 @ 111.66 2015 Martin FAST/FS race 1968 Pontiac Firebird 400 TH400/3.08 open export car - factory heater delete 14.48 @ 95.86 w/ 2.14 60' 2018 Pure Stock Drags 14.47 @ 95.02 w/ 2.16 60' 2019 Martin FAST/FS race |
Update
I used a local "old timer" brake specialist here in Atlanta to rebuild all 3 valves for me. He said they were very gummed up but sleeves were not needed. Took one week and the cost all in was $170. I wont be ready to install system for a month or so and I hope they work fine.
1970 T/A |
