Old 02-14-2020, 11:35 PM
Stuart's Avatar
Stuart Stuart is offline
Was the original big car shift lever also round like the A body shifter in your picture above?
Not that it has anything to do with this discussion, but this is a picture of the aftermarket Hurst I put in my '61 (I still have the original Inland shifter, but it's stored away in a box out in the garage.)
  #242
Old 02-17-2020, 02:01 PM
SD455DJ SD455DJ is offline
Stuart, I believe the shifter arm is round like the A/F-bodies.
Name:	65-68 B-body Shifter Illustration.jpg
ID:	532247   Click image for larger version
Name:	65-68 B-Body Shifter Illustration 2.jpg
  #243
Old 02-17-2020, 02:11 PM
Here are the P/N's for the shifter assembly, arm, rods, and levers underlined in red that we are looking for. The 67/68 4-speed shifters and hardware are completely interchangeable except for the shifter assembly (67 - 9786898 vs. 68 - 97900770). Not sure what the differences would be...? Interesting there is only one shifter arm for both buckets with and w/o console and bench seat...9787946. The 1/2 and 3/4 levers are the same p/n.
Dennis
Name:	68 B-Body 1-2 Shifter Rod 4.035_LI.jpg
ID:	532249   Click image for larger version
Name:	68 B-Body 3-4-R Shifter Rods 4.035_LI.jpg
ID:	532250   Click image for larger version
Name:	68 B-Body Shifter Asm. 4.004_LI.jpg
ID:	532252   Click image for larger version
Name:	68 B-Body Shifter Levers 4.045_LI.jpg
ID:	532253   Click image for larger version
Name:	68 B-Body Shifter Arm 4.006_LI.jpg
  #244
Old 02-19-2020, 08:35 AM
I see that the pictures of the P/N's I posted below are difficult to read, so I transcribed them:
Group 4.035 / Gearshift Control/Rod / 1st & 2nd / 9786892
Group 4.035 / Gearshift Control / Rod / 2nd & 3rd / 9786893
Group 4.035 / Gearshift Control / Rod / Reverse / 9786894
Group 4.004 / Shifter Asm. / Transmission Control / 9790770
Group 4.045 / Lever / on Transmission Shifter / 1st & 2nd / 3rd & 4th / 9778644
Group 4.045 / Lever / on Transmission Shifter / Reverse / 9778645
Group 4.006 / Lever / Transmission Gearshift Control / 9787946
If anyone has any of these parts, please feel free to PM me.
Dennis
  #245
Old 02-22-2020, 10:52 AM
Dan made more progress this week with lots of small stuff that is hard to see, or hidden. Interior - steering column, pedals, e-brake, & kick panels; Engine compartment - clutch & throttle linkages, and more firewall details.
Dennis
ID:	532702   Click image for larger version
ID:	532703   Click image for larger version
ID:	532704   Click image for larger version
ID:	532705   Click image for larger version
  #246
Old 02-22-2020, 11:03 AM
higgenslake higgenslake is offline
Which shifter arm is that?
  #247
Old 02-22-2020, 12:18 PM
The wrong one. We are currently looking for a correct 67/68 B-Body shifter handle. According to the parts and assembly manuals, there was only one style for all seats with, or without console.
Dennis
  #248
Old 02-22-2020, 02:52 PM
keith k keith k is online now
Awesome car. It's very lucky to have acquired Dan as its owner
  #249
Old 02-24-2020, 11:20 AM
mr67gp mr67gp is offline
Dennis
I have one (allegedly). Are you looking for a part #? I will be using it for my GP changeover, unless I use the RG shifter instead. Too far away from that decision to let it got yet.
Jim K in PA
1967 GP HT 428
1967 GP convert 428
1957 Chieftain 4D HT
  #250
Old 02-25-2020, 02:03 PM
mr67gp, Let me know if you decide to part with it. We are looking for the shifter handle primarily, but are interested in all the 67/68 4-spd hardware...rods, levers, shifter body, & handle.
Thanks, Dennis
  #251
Old 02-29-2020, 08:00 PM
Default Need a Clean Rust Free 68 Hood
I thought we'd start here with putting out the word that we are looking for a nice straight, clean and rust free '68 hood for the Catalina. The original one is straight, but has some rust through along the back edge bottom brace structure. It can be repaired with new metal welded in, but we wanted to at least see if there is a good hood needing a cool car to go on. Thanks!
I'm also putting an ad in the classifieds too.
Dennis
  #252
Old 03-01-2020, 02:45 PM
Dan made some more progress with a lot of little things on and around the engine and firewall. The pedals are attached and at their proper installed positions. Dan's getting a bunch of factory breather tubes black phos plated and the front end sheet metal is ready for paint. Dan also decided to reupholster the front and rear seats with the original fabric and vinyl from SMS, since the original upholstery just wasn't quite nice enough to match the rest of the car...you know how that goes. Good steady progress with all the other work he has got going.
Dennis
ID:	533459   Click image for larger version
ID:	533460   Click image for larger version
ID:	533461   Click image for larger version
ID:	533462   Click image for larger version
  #253
Old 03-01-2020, 05:43 PM
Core support assembled and ready for installation. The original 4-core heavy duty radiator is being cleaned and painted next...looks like it was recored not long before the Cat was retired from the street...very clean inside.
Dennis
ID:	533477   Click image for larger version
  #254
Old 03-01-2020, 08:12 PM
Stuart's Avatar
The old "while we're at it."
  #255
Old 03-02-2020, 10:10 AM
Ben M.'s Avatar
Ben M. Ben M. is offline
Very nice!
  #256
Old 03-05-2020, 01:55 PM
Dan got more little stuff done in and around the engine, as well as the polished original 3-piece rear wheel well moldings.
Dennis
ID:	533854   Click image for larger version
ID:	533855   Click image for larger version
ID:	533856   Click image for larger version
  #257
Old 03-05-2020, 05:09 PM
1_Wild_Cat's Avatar
I so dig everything in this thread...Such a cool car and such beautiful work - all the attention to detail. Sincerely - Thank You for taking the time to put this thread together.
  #258
Old 03-05-2020, 05:33 PM
1_Wild_Cat - Thanks! We know some folks appreciate seeing what it takes to restore a non-mainstream Pontiac, and this one in particular deserves it. We are happy to share what we know, as well as the progress and problems we encounter along the way. These big boys are definitely more challenging to find suitable parts for when you need them.
Here is another little hiccup...Dan has to relocate half the plastic attachment pins in the reproduction door weather-stripping...ridiculous! But, that's what you have to do. We are sure they are patterned for the Chevy variant and the other GM division brothers have to make do and 'fix' the Chevy made junk.
Dennis
ID:	533863   Click image for larger version
  #259
Old 03-05-2020, 06:21 PM
The doors are done (weather-stripping fixed and attached) and you can just see the glove box door is installed. The dash pad, A-pillar covers, and speaker cover get installed tomorrow.
Dennis
ID:	533881   Click image for larger version
  #260
Old 03-05-2020, 10:40 PM
Stuart's Avatar
Every day I check for new posts in this discussion. Can't wait to see it finished.
The Following User Says Thank You to Stuart For This Useful Post:
