Old 02-17-2020, 01:35 PM
OG68 OG68 is offline
It can be a challenge to place all the belts together when mounting, particularly bench seats with the separate shoulder belt. If you look closely at the mounting ends of the belts, you will notice that they are not flat but slightly bent, some more than others. This provides a "nesting" pattern for the belt ends when bolting to the floor. Check your Fisher body manual for the proper sequence of which belt is at the bottom, middle and top.
2007 Cadillac SRX
Old 02-18-2020, 01:13 AM
Verdoro 68's Avatar
Success! Guess I just needed some time away from it, seems obvious now. Thanks for the help.
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - 3.55 posi (build thread | walk around)
