Header bolts
Im not sure what I did before. When installing headers, should I use moly on the bolts or dry?
Thank you!! Last edited by ITSBACK; 10-01-2019 at 10:26 PM. |
I use copper anitsieze.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
Thank you. I was going to use Molly but I pictured it getting hot and melting and dripping out.
No moly grease, big mess.
Really only need antiseize if it's aluminum heads, iron heads you can go dry.
Interesting. I always use stainless ARP bolts and install them dry because I worry that the additional lubrication is going to have the bolts backing out. No use in using Loctite since heat returns the Loctite to a liquid and back into a semi-lubricant. Anti-seize with a high heat rating should stay in place but I worry about lubricating the threads and bolts unscrewing.
So I don't have an answer and can only say that when the headers have needed to come back off there hasn't been any problem with unscrewing the dry install stainless bolts - but I do live in a really dry area and don't have any corrosion type problems anywhere on the cars.
summit carries stainless header bolts that are serrated on the underside of the head, i use anti seize on them & they dont back out. very cheap too, like $15 for a set of 12.
I use the ARP ones, they don't back out for me with anti-seize, I checked them somewhat regularly even. .
https://www.summitracing.com/parts/sum-g1490 |
Nice! Thank you! Yeah, I see they have 12 points too. That's about half the price of ARPs.
