Tri-Power Tech 57-66 Tri-Power Talk
Old 10-09-2019, 11:11 PM
footjoy's Avatar
footjoy footjoy is offline
Default will a 65-66 tri power work with a PTC121 timing cover
I was wonder if a 65 or 66 tri power intake will fit with a 69-7? timing cover?
It is a BOP Engineering PTC 121
Old 10-09-2019, 11:13 PM
tom s tom s is offline
Depends if it has the dimple to clear the thermostat housing.Post a pic of the backside top of it.Tom
Old 10-09-2019, 11:16 PM
footjoy's Avatar
Well it doesn't look like it.
Thanks for the info.
Greg
Old 10-10-2019, 11:37 AM
footjoy's Avatar
Picture of timing cover no bump out for tri power.
Old 10-10-2019, 01:39 PM
Dick Boneske's Avatar
You should have no problem finding a timing cover that does have the dimple.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 10-11-2019, 09:16 AM
footjoy's Avatar
Is it possible to change a timing cover and get everything sealed up.
Do I have to loosen oil pan to get it out? ( old sbc guy)
Old 10-11-2019, 10:01 AM
Kenth's Avatar
Kenth Kenth is offline
Yes, you can do it w/o dropping the oil pan.
Remember to torque the damper bolt to at least 160lb/ft.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
