Old 01-26-2020, 07:43 AM
elefantrider's Avatar
elefantrider elefantrider is offline
Thanks! Could I just cut out the damage section under the vinyl and repair that part only so the original paint is not disturbed? Looks like the window needs to cone out to be done correctly, and for the vinyl to be replaced around there? At the factory, the vinyl got done before the window was set in? It looks to have been tucked in tight around the window.
Old 01-26-2020, 11:49 AM
LATECH's Avatar
LATECH LATECH is offline
Originally Posted by LATECH View Post
I replaced mine.
They call it a tulip panel (at least that is what I bought)
This here is one.
Pretty easy fix
I even used lead at the side seams like the factory
https://www.ebay.com/itm/1964-1965-C...UAAOSwWdZZZjuK
You can try. Chances are the metal is thin and will likely burn holes when welding it. And you will get so close to the paint, it too will burn and peel.
Best to figure on removing the back window and replacing the entire panel.
Also , when re installing the window, use butyl tape. I have had my back window out 3 times now , because the Urethane keeps pulling loose from the glass. The " New " glass guy I have said that the fit of the window to the body is not a uniform fit and that is what is causing it.
Rust is always worse than it looks. Trust me .Plan on replacing the entire panel.
I doubt the vinyl top was installed under the window/seal
Old 01-26-2020, 02:47 PM
Agree. Rust is usually worse than it appears. But only on this car, only the area under the lower window vinyl is crusty. That area and the trunk pan.
The window trim is missing. Is that still available?
It looks like there is a rusted bracket under the hole. Is that supporting the windshield?
I was hoping an epoxy or lead job can fill it up but I don't think so.
Old 01-26-2020, 03:17 PM
LATECH's Avatar
https://www.opgi.com/moldings/window...s-g240882.html
Old 01-26-2020, 03:19 PM
LATECH's Avatar
https://www.opgi.com/gto/1964/vinyl-tops
Old 01-28-2020, 09:08 PM
I hope the gas tank mounts are still solid. I guess i won’t know until I drip the tank to inspect it.
Do they also rust and get weak if the pan is rusted through in spots?
Old 02-16-2020, 04:42 AM
Who makes the best repair panels or are they all the same?
Old 02-16-2020, 06:25 AM
Bill Hanlon's Avatar
Interesting Freudian slip
Old 02-18-2020, 02:52 AM
I didn't drop or drip the tank, just siphoned out as much as I could and poured fresh gas in.
The kerosene smell is still there but I suppose it will eventually dissipate.
What about the quality of the pans or are they all the same.
Old 03-28-2020, 11:22 AM
What can one expect to pay a body shop to weld in a new trunk floor if I provide the panels?
Old 03-28-2020, 11:24 AM
This is why the trunk pan got shot. Window channel under vinyl top is rusted. Has anyone repaired the channel before? Does it require a donor chann el? Is the vinyl top pattern still available?
https://forums.maxperformanceinc.com...8&d=1579983967
What can one expect to pay a body shop to repair this channel with new metal?
I have got a range between $700-$1000.
That includes R&R the window.
Old 03-29-2020, 09:08 PM
kencar62's Avatar
kencar62 kencar62 is offline
Default Window Channel
Try Belden Speed. They have the channels.
http://www.beldenspeed.com/rust-patc...lemans-tempest
The Following 2 Users Say Thank You to kencar62 For This Useful Post:
Old 04-01-2020, 12:16 AM
aceaceca's Avatar
aceaceca aceaceca is offline
How about a monkey wrench in the mix. My floor was almost identical to yours. Maybe a bit more rust through on the left.
I have the 3 panel repair for it. However, I do not do that work myself. Decided to go with fiberglass. Used acid to kill the
rust. Primed it in DP40. Fiberglassed the whole trunk floor. Put tape on the gaping holes to prevent run through. Think I used double
fabric thickness In separate applications. I am very pleased with the way it came out. Once I re prime it and spatter coat it
it will look as new. I can post a pic if you like.
Old 04-01-2020, 10:45 AM
Yes, would be interested to see a pic please. I am thinking fiberglass also but my bodyman says it will not last.
My concern is if I put something heavy in the trunk, will it hold? Once the mat is on, you do not even see it.
Old 04-03-2020, 10:28 PM
aceaceca's Avatar
Here is a link to my trunk repair and rear window surrounds. What a mess that is. It is difficult to see the repair on the trunk because the
fiberglass is translucent. I can assure you though it is very strong. Fiberglass is very nice stuff to work with once you have had a few tries.
I use it to repair all sorts of things. The silver showing through is aluminum tape placed over the larger holes to prevent run through of
the resin and glass Anyone who thinks it will not last are simply wrong. Even if the floor continues to rust away, you essentially have a
one piece mold of fiberglass trunk pan that is not going anywhere. With two plies of glass it is very strong.
https://photos.app.goo.gl/3nw6QsuyZWvJNahQ8
