"help" best removal product
My door trim was starting to fall off, it was held on by double sided tape. I removed the molding the rest of the way and now i'm left with a sticky mess. What product works best to remove the left behind adhiesive. The sticky gooiey stuff that is left on the door after peeling off the double sided tape.
Thanks, Gregg |
Gregg try some naptha ( local hardware ) takes away glue wont hurt the finish, wear cotton a spark can ignite the rag, when done soak the rag in water rap up wet then discard.
Hope this helps Gregg |
Have you tried an eraser wheel yet? Its like a big pencil eraser that you hook to a drill. Works pretty slick. Doesnt damage paint at all.
http://www.amazon.com/3M-7498-STRIPE.../dp/B00063VT0G |
Lighter fluid works well. But it is just naphtha like previous post.
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
It’s amazing what vegetable oil will cut through, and it’s something that you most likely already have around the house. Tip for grease penetrated into skin: Rub vegetable oil into dry hands. Next, without any water, work dishwashing soap into hands. Start with just a few drops of water, scrub then keep adding water.
3m makes a product "general adhesive remover" ina quart can that should work. Irgoatmike
we used to use enamel reducer,good luck.Tim
Denatured alcohol is another option to consider. It's great on adhesive residue and other stu.ff. My motto is to use the weakest solvent or cleaner that will still do the job.
