Old 08-26-2000, 11:54 PM
Guest
Posts: n/a
this is the only description i could give this sound coming from my rear end.
i have a 308 12 bolt limited slip out of a 68 442 in my lemans,and this has been going on for the past 2 weeks.
the rhythm gets faster with the speed,and sometimes it's loud!
then all of a sudden for about ten or fifteen seconds,it stops.
are my gears toast,or something else?
Guest
Posts: n/a
Old 08-27-2000, 01:14 AM
Bracket Racer Bracket Racer is offline
Better pull the cover off and check it out or get signed up with triple A soon, cuz if you keep driving it, your likely going to need a tow!
Old 08-27-2000, 09:25 PM
Half-Inch Stud's Avatar
If you can provoke this noise by going into reverse...stop driving and start peeking inside.
Otherwise it's quit simple to pull the axles and inspect the wheel bearings. Doesn't hurt to inspect what you bought.
"his peg-leg got woodworm , and broke into three"--G. Baker
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct
Old 08-28-2000, 01:44 AM
it might not hurt to check the rear u-joint also. i'd for sure check the bearings in the rear end especially the pinion bearings. mike
former." --Albert Einstein
- Winston Churchill
Old 08-28-2000, 06:10 PM
Guest
Posts: n/a
BANZAI!i jacked the car up,and put it in drive,and guess what?not one,but both axles are bent!!!both axle seals are oozing.
i went to the good old country junkyard,and found a 10 bolt out of a 72 malibu for $75.now to jeg's for the posi stuff.
anybody want a 12 bolt with bent axles?never mind.
