Old 09-18-2018, 07:00 PM
avman avman is offline
Default Loaded on the trailer for the Quick Performance 9" and disc brakes install
Heading to the "doctor" tomorrow at dawn for the Quick Performance 9" rear axle assembly, Wilwood disc brakes, and UMI suspension components.
ID:	493059   Click image for larger version
  #62
Old 09-20-2018, 10:36 AM
UPS "LOST" a 40 POUND package!
My axles, plates and bearings were allegedly "lost" by UPS.
The axle housing arrives Friday (tomorrow).
The GREAT news is that Quick Performance is cutting a new set of axles today and sending them along with everything else that UPS "lost" out today, so by Monday the shop will have everything!
  #63
Old 09-20-2018, 06:06 PM
UPS "lost" not one, but TWO packages from Quick Performance!
The shop got started on the GTO today, we thought the first 3 boxes delivered Monday was all of the Wilwood front disc brake system parts, and....NO FRONT DISCS!
Did a track, and it showed one of the 3 boxes was "lost"...No call, no email, no notification from UPS.
Once AGAIN Max at Quick Performance STEPPED UP for us-their customer-and shipped ALL of the parts UPS "lost" and Max also called the shop doing the work to see when they needed the missing parts by, and took care of any cost involved in expedited shipping.
Thank God that Quick Performance cares about their customers, because I have found through the years that BOTH FedEx and UPS DON'T CARE, it's ONLY about the bottom line for them!
Quick Performance = A+ for taking the extra time and costs to make this happen in time for my wife to have her car ready for Crusin the Coast.
UPS = utter FAIL and they don't care on top of failing!
  #64
Old 09-26-2018, 09:57 PM
Went to the shop today...
WOW!
Before I post the awesome pix, I am having a local outstanding driveshaft shop mod the existing driveshaft so it is the correct length, balanced, and has the 1350 pinion yoke/U-joint compatibility for the bulletproof QP rear axle chunk.
The shop owner recommended getting a slip yoke for the Muncie 4 speed that is also compatible with a 1350 U-Joint on the transmission end and an aluminum driveshaft. I certainly don't want a much smaller U-Joint on the transmission end like we will have for now, but I really would appreciate advice and sources for the slip yoke that can have a 1350 U-Joint and what about Chrome Molybdenum instead of aluminum?
Please help!
Enjoy the pix!
ID:	493701   Click image for larger version
ID:	493702   Click image for larger version
ID:	493703   Click image for larger version
ID:	493704   Click image for larger version
  #65
Old 09-26-2018, 10:00 PM
More pix
ID:	493706   Click image for larger version
ID:	493707   Click image for larger version
ID:	493708   Click image for larger version
ID:	493709   Click image for larger version
  #66
Old 09-26-2018, 11:03 PM
64speed's Avatar
64speed 64speed is offline
Get the yoke from summit
  #67
Old 09-26-2018, 11:37 PM
Slip yoke for the Muncie?
  #68
Old 09-27-2018, 04:55 PM
GTO ready tomorrow.
Shop did amazing, detailed, thoughtful, meticulous work!
Trailering it home so I can run it through the heat/cool cycles for the new rear end...
MAN! I can't WAIT!
  #69
Old 09-27-2018, 07:56 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Looks nice should handle good.
Color Iris Mist?
Skip Fix
  #70
Old 09-27-2018, 10:39 PM
Yes, Iris Mist
Truly spectacular color, especially at dawn and dusk.
My goal is a good cruising experience, but bulletproof GREAT quarter mile launch and traction performance, the exact opposite of what the open diff R.I.P. 8.2 was...
  #71
Old 10-05-2018, 05:49 PM
bbnotop bbnotop is offline
avman, looks nice and thanks for the pictures. I just put the same axle in my '64. Do you know what your shop did regarding the parking brake cables? I see you have the stock cables hanging there. QP told me you can use the stock ones, but the rear sheeting is about 4" short between the frame bracket and the rear disc bracket. Any insight would be appreciated. Thanks, Steve
  #72
Old 10-07-2018, 08:40 PM
AG's Avatar
AG AG is offline
You might want to consider an aftermarket (Strange, Denny's etc) driveshaft, instead of reusing the stock one with upgraded yokes an U-joints. A strong axle with a weak driveshaft might be an issue, not sure of the purpose of the vehicle. If it's just street you should be ok, but if you are going to race it with tire it could be a problem.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
  #73
Old 10-07-2018, 09:45 PM
mf67gto mf67gto is offline
bbnotop - I just went thru this on my '67 GTO. Put a Currie 9" in with KORE3 C6 Z51 rear brakes - uses a pull type lever vs what we have on stock drum brakes. Vic at Control Cables built me the two correct cables for brackets and levers - connected up to rest of stock system for about $30 each. Website is http://www.controlcables.com/parking-brake-cables-2/ -
Fast turn around and a great guy to work with too! Take some pictures and measure at axle full droop. He will most likely know the ends to put on. My park brake cables look factory. I am quite happy with them.
Good luck!
  #74
Old 10-10-2018, 10:57 AM
mf67gto, thanks for the info and I will contact those folks. (And then I will be listing a pair of brand new stock P-Brake cables......)
  #75
Old 10-17-2018, 11:15 AM
Tom Vaught's Avatar
Boost Engineer
Very Nice 9" Installation there, Congrats on the work done.
Tom V.
I run air bags and a 9" too.
  #76
Old 10-25-2018, 11:23 PM
NO67GTO's Avatar
NO67GTO NO67GTO is offline
avman, nice build so far. I'm doing the same thing in my 67 race car.
I got a QP 9" 3.90 pro gear, spool, 1/4" axel tubes 35 spline Axel's and the Ford disc brakes. Max was my salesman, great guy!!!!!
So far I installed the empty housing and mocked up the anti roll bar.
I have to weld the brkts to the housing and the link brkts to the frame. Then I can assemble the rest. I went with Qa1 double adjustable shocks
Sent from my XT1254 using Tapatalk
Giving To Others!!!
V.P. Pioneer Valley GTO Association
www.pvgto.com
67 Lemans 455 best et. 12.023@ 111 mph LVD 9/2008
68 GTO H.O. in progress?
