1973 firebird core support threaded washer
looking for two of these , does anyone make them or looking for 2 good ones
bump
Ames sells them
Really? was on page 237 ( F25) and only see the old camaro bolt and nut and washers?
Also these were made in '75 And up with No indent ( completely flat) because the car header panel located the nose . Thoughts? |
Sent from my iPhone using Tapatalk |
I just looked, I don’t see them either anymore
Forgot I got new catalog, they are generic,
Looks like FS763B is the 70-71 style and would work if it has tabs to locate the nut in the bottom subframe hole.
i did buy these they do not have any tabs to keep them in the hole like the original ones
You can weld a washer on the bottom. I think that was mentioned, and the size needed, in the video. It NEEDS to be located so the core can only move side to side. This sets the front to rear distance.
I wonder if they're just using the AMK shims?
https://www.amkproducts.com/search-result/?ser=9790393
So long, farewell. |
Like I said in the video, I welded a nut on top and washer on bottom to make it work correctly. The washer needs to be 2.5 diameter. could weld a washer to the bottom of a 75-77 unit as it is flat and has no "indent" because the header panel sets the distance. |
this is what i got from ames
Yeah, thats not going to stay in place in the subframe. .
I may buy some from AMK and weld washers and nuts on them for people. |
let me know i will buy some , thanks for all your knowledge
still looking for the 73 ones
I have these for sale,$50 plus shipping Sent from my iPhone using Tapatalk |
L4L 9A6 |
I’ll have to get a quote tomorrow
ok thanks
