Old 05-13-2020, 09:55 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
Default 63 Ralley gauge mod
I think this should work , just got to fab a small brace for the lower right corner.
ID:	540108   Click image for larger version
Old 05-14-2020, 10:54 PM
Sledder_duner Sledder_duner is offline
Looks pretty good! Here is mine with speedhut gauges.
ID:	540240   Click image for larger version
Old 05-15-2020, 12:59 AM
hobbygto65's Avatar
What kind of money do they get for those?
Old 05-15-2020, 05:48 AM
I spent like 700. Speedo is gps and the tach is a shift light style and the others are programmable with the warning lights.
Old 05-15-2020, 10:34 AM
hobbygto65's Avatar
Nice, I've never heard of them. About on par with Dakot Digital.
Old 05-20-2020, 10:04 PM
xlrate's Avatar
xlrate xlrate is offline
How about something like this? : A modified 66 GTO (repop) replaced GTO battery Light with Tempest Volt meter all gauges now.. 66 GTO has similar gauge face style & color as the 63.
Old 05-20-2020, 11:16 PM
hobbygto65's Avatar
Tempests had a ampmeter. Not sure when they started using voltmeters.
Old 05-21-2020, 07:11 AM
xlrate's Avatar
Post did not go as planned meant to say & post pic:
How about something like this? : A modified 66 GTO (repop) replaced GTO battery Light with Tempest Amp meter all gauges now.. 66 GTO has similar gauge face style & color as the 63.
Old 05-21-2020, 12:23 PM
hobbygto65's Avatar
How about a close up of the ampmeter pod?
Old 05-21-2020, 12:32 PM
Really like the "what have could been" '63 Rally instrument clusters using the '65 & 66 Rally clusters, plan on doing something similar on my '63 LeMans. Hobbygto65, did you repurpose a '65 Rally cluster or go with partsplace repro pieces?
xlrate's Avatar
I cut out the battery red lens and made the hole larger and flip over the old amp gauge and epoxied it in.
Old 05-21-2020, 06:52 PM
hobbygto65's Avatar
I used a new repo from are sponsor, there from the Parts place thou. The only bracket that doesn't work is the one where the clock would be. Where that bolts to will have to be cut out to make room for the gauges. I planned on just putting a screw though the plastic into the metal below the gauge.
Old 05-21-2020, 06:58 PM
hobbygto65's Avatar
The reason I used the repo is the tach is supposed to work with HEI.
Old 05-21-2020, 08:49 PM
xlrate's Avatar
I have an electronic setup and had to use a MSD tach adapter. I put my setup together 8-9 years ago from an Ames Repop kit.
