Old 07-11-2020, 07:56 PM
I got a replacement windshield installed, at my house in my 72 Lemans convertible for $300. After watching them, I wouldn't have wanted to do that one myself. I have replaced my 55 Chevy and 80 Fiat spider conv. , and they're all different. If you do it yourself, be mindful of how much seal you put on and how much you press your new glass to the seal for your moldings to fit.
Old 07-11-2020, 08:00 PM
mrennie's Avatar
mrennie mrennie is online now
Originally Posted by crustysarge View Post
I made a mistake and laid the ribbon a little high on the bottom and you can see half of it beyond the stainless molding but so be it, this is not a $100K car.
I am leaning towards using the ribbon when I install my glass. One thing I wonder was if it would work out better to lay the glass on a padded work stand with the interior side up, then apply the ribbon around the edge of the glass. This way you know the ribbon can't be in the wrong spot (too high/too low) when you put the glass into position.
Does this sound like it would work?
Michael
Oshawa built 1 option Judge basket case. 463, SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. 24 year project almost done...
Old 07-11-2020, 08:01 PM
MUSLCAH MUSLCAH is offline
These cars had butyl tape from the factory......and that’s what I used in my front and back glass 67 gto. The butyl tape gives you the correct height ,for the the glass....so the moldings fit correct.
Old 07-11-2020, 08:05 PM
I’ve always put the tape on the channel.....and all the Windsheild guys I’ve had in my shop ovah the last 40+ years ...do it that way.. plus it’s nice to have those pump up suction cups....Incase you have to slide the glass ,one way or the othah..
Old 07-11-2020, 08:32 PM
brad900 brad900 is offline
A 67 GTO never used butyl tape. Look in the Fisher body service manual, only used urethane
Old 07-11-2020, 09:11 PM
Well they must have run out of urethane that day...cus my ORIGINAL WS ...had butyl .
Old 07-11-2020, 09:53 PM
TedRamAirII TedRamAirII is online now
The Butyl can keep your spacing correct, and used as a dam to hold the Urethane.
Bill Nye.
Old 07-11-2020, 10:39 PM
Here you go
http://www.beldenspeed.com/technical...lation-details
and here you go
Below from John Hinckley. If you don't know who he is, here's a little info. http://www.corvettemuseum.org/librar...hinckley.shtml
John Hinckley: "GM never used butyl tape or anything like it to install windshields or backlites. Period.
The body opening flange was coated with black silane primer using a flow-brush 30 minutes prior to installing the glass, and all the reveal molding clips were installed to the Body Shop-installed weld studs.
The glass was placed on a powered rotating fixture, inside edge up, retained by suction cups.
The glass periphery was cleaned using a solvent, dried, and a different silane primer was applied.
A fabric-reinforced self-adhesive foam rubber "dam" was extruded and applied to the glass just inboard of where the Thiokol adhesive would later be applied; the purpose of the "dam" was to contain any Thiokol "squeeze-out" so it wouldn't show from the inside past the edges of the interior garnish moldings after the glass was installed to the body.
After dam application, pumpable Thiokol adhesive (with a pyramid-shaped cross-section created by the dispensing tip) was applied adjacent to the dam, all the way around the glass.
Lower glass supports were fixture-located and screwed to the cowl, and rubber spacer blocks were glued to the opening flange. The spacer blocks set the height of the glass relative to the body to ensure a good fit of the reveal moldings.
The prepared windshield was removed from the rotating fixture, installed in the body opening, and pressed down against the rubber spacer blocks; wooden tonque depressors were used to "paddle" the Thiokol around the edges at a 45* angle from the top edge of the glass to the bottom edge of the body opening to ensure a continuous seal all the way around the glass.
Reveal moldings were installed.
That was the plant production process, and explains what is sometimes described as a "rope" being found when an original windshield is removed - the "rope" is the fabric-reinforced rubber "dam" that was applied prior to applying the Thiokol adhesive.
If you'll look in Section 4 ("Fixed Glass") in the Fisher Body Service Manual, you'll see exactly the same process for windshield replacement, except the "dam" wasn't included with the Service kit - masking tape was used instead to control "squeeze-out".
The Thiokol installation passed the Federal MVSS windshield retention tests, and contributed substantially to the body's torsional stiffness; it also helped the structure pass the roof crush test. It's illegal to replace a windshield with butyl tape, although some glass shops do it as a less-expensive short-cut method instead of doing the job right."
Old 07-11-2020, 10:53 PM
pippintook pippintook is offline
I had a mobile glass come and install front and rear glass on my 78 Trans Am. The install cost was $70 for front and $70 for rear. I reused the old rear glass and he sold me new front glass for $150 - this was about 5 years ago. The installer used
SikaTack Drive Adhesive and a Dewalt 18-Volt Adhesive and Caulk Gun. I posted some pics in this thread
http://forums.maxperformanceinc.com/...ght=windshield
Old 07-11-2020, 11:17 PM
Thanks for that info Brad900
Old 07-12-2020, 08:56 AM
72projectbird's Avatar
I made the mistake of using urethane for the windshield on my 71. The glass sits too low in the opening, making the trim fit weird.
Ever since, I've been using the correct thickness butyl and everything lines up perfectly.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 07-12-2020, 09:34 AM
jimib's Avatar
jimib jimib is offline
I've heard and read that using urethane can make this project a challenge regarding thickness. I'll certainly need shims at this bottom of the windshield.
1967 GTO, hard top, 400 Block, Butler Performance Build, EFI Holley Sniper, Tremec 5-Speed, Moser 373 Rear, 4 Wheel Disc Brakes
Old 07-12-2020, 09:51 AM
78w72 78w72 is offline
the install height of the glass depends on how much & the way you put the urethane on, sounds like you didnt use the proper amount. the pro that did mine specifically stated the urethane needs to be at a certain height/amount to get the correct height, thats the ~1" tall thin wall of urethane i mentioned & how he cut the tip. my trim installs & sits right, just like it did before it was replaced.
Old 07-12-2020, 10:04 AM
You needed to use spacers & have the right size tip. This is the reason to pay a pro
The Following User Says Thank You to brad900 For This Useful Post:
Old 07-12-2020, 03:34 PM
I always put the sealant on the channel rather than the glass. Can't see a reason not to. If it's on the channel, you KNOW it's in the right place.
On the butyl tape question, I use it on my older cars but i agree with brad900 and I can't remember where, but I was surprised to read somewhere, sometime ago that it was not actually 'butyl' tape from the factory but some other product that I was unfamiliar with. I still use it though.
Interestingly, my 1980 280zx FSM instructs you to put the quarter windows in using butyl tape...by name... So, that's what I did.
Wherever I read what I just mentioned and as I recall it was an online magazine article, also said that urethane was a gov't safety requirement in the early '70s so that the windshield wouldn't go flying out of the car in a crash, not for it's improved water sealing. Don't get me wrong, it's great and once cured, it takes an act of congress, or at least a hot knife, to get it out. For me, I don't put my cars together with surviving a crash much in mind so I use the butyl and never have had a problem. One more observation, on our mid/late '60s cars, the trim has more to do with keeping the glass secure than the sealant. I knew a guy with a '68 hardtop that lost his back glass while flying down the interstate with all the windows down and no trim on the back. He said he stomped it to the floor and 'POOF!'
That wouldn't happen, I don't think, with fully cured urethane.
Old 07-13-2020, 01:28 AM
A pro did install it, through my insurance no less.
I usually do all my glass myself using butyl, but figured I'd use my insurance to replace my cracked windshield.
Hell I've installed 3 windshields/back windows this summer alone, and all 3 have come out perfect using butyl. It's pretty nice buying a few rolls of it and doing it yourself. A hell of a lot cheaper too.
1987 Grand National
Old 07-13-2020, 03:04 PM
crustysarge crustysarge is offline
I used 3/8 on the front with non original glass and 5/16 on the back with original rear window, worked just right for height on trim.
  #38
Old 07-13-2020, 10:09 PM
mrennie's Avatar
Sorry if I am being dense here, this will probably be more apparent when I actually get to installing the glass...but I don't understand how butyl applied around the edge of the glass could be anywhere but in the correct location?
What am I missing (aside from the fact that this is not the "normal" way it is done)?
Michael
  #39
Old 07-13-2020, 10:54 PM
You're right and I'm sure you won't have any problem doing it that way.
Old 07-13-2020, 11:10 PM
Yah fingahs might stick to the butyl tape ,when you handle it,for the install. And yah might eff up the placement of the butyl.....but what do I know..
