Old 07-09-2020, 09:02 AM
64speed's Avatar
64speed 64speed is online now
Default Turned the wrong way
I had my nephew turning my engine over while I ran the pump just to keep things lubed like my machinist said. After about 8 1/4 revolutions I realized my never was turning it clockwise. Any reason to suspect damage? I turned it back counter clockwise and nothing seemed amiss.
Old 07-09-2020, 09:05 AM
Formulajones's Avatar
What do you mean??
Clockwise at the crank is correct.
Only the distributor turns counter clockwise because it's on the other side of the camshaft.
https://youtu.be/XqEydRRRwqE
Old 07-09-2020, 09:08 AM
RocktimusPryme's Avatar
What do you mean??
I was thinking the same.
Either way I doubt there would be any damage. Ive moved backwards before while looking for TDC and all. Never that many turns, but I cant see how it would be a problem.
Old 07-09-2020, 09:42 AM
You could have spun the oil pump backwards and it still wouldn't have hurt anything in 8 or even 10 turns. Just not enough pressure to wipe an oil film gone.
Clay
Old 07-09-2020, 09:47 AM
Navy Horn 16 Navy Horn 16 is offline
Smokey Yunick, who won the Daytona 500 with a Pontiac, is famous for devising engines and complete drive trains that ran "reverse torque", essentially running the opposite direction. It helped the cars turn left.
Engines don't care what direction they turn, as long as they have oil.
77 Trans Am, 469 w/ported E-Heads via Kauffman, matched HSD intake, Butler Performance forged rotating assembly, Comp custom hyd roller, Q-jet, Art Carr 200 4R, 3.42s, 3 inch exhaust w/Doug's cutouts, D.U.I. Ignition. 7.40 in the 8th, 11.61@116.07 in the quarter...still tuning.
Old 07-09-2020, 10:39 AM
64speed's Avatar
Turning it with a breaker bar on the crank clockwise. Maybe a full combustion cycle at best
Old 07-09-2020, 11:11 AM
grandam1979 grandam1979 is offline
He turned the engine by hand while you ran oil pump with drill counterclockwise? If so your fine
Old 07-09-2020, 11:45 AM
Biggest problem with engines that sit for a long time isn't bottom end lube.
It's wrist pins and cylinder walls.
Clay
Old 07-09-2020, 12:42 PM
72projectbird's Avatar
It's fine.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 07-09-2020, 12:45 PM
scott70's Avatar
scott70 scott70 is offline
You might want to check the torque setting on the balancer bolt. Other than that it shouldnt hurt anything.
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
Old 07-09-2020, 01:21 PM
rustedgoat rustedgoat is offline
Old Pontiacs are not like some newer engines with chain and belt tensioners that could cause problems if they become unloaded.
"Honestly the car will only be there for a few weeks, OK maybe a month at the most"
Old 07-09-2020, 02:38 PM
Tom Vaught's Avatar
Boost Engineer
When he was turning it backwards, the only difference was the oil pump was no longer moving any oil upward to the block/oil filter. Turning the engine by hand 90 degrees at a time and spinning the oil pump with a properly modded distributor tool just makes sure all of the rods and bearings, and the lifters/rockers got a dose of oil before fire-up.
Tom V.
Old 07-09-2020, 03:16 PM
leeklm's Avatar
leeklm leeklm is offline
You are more than fine as clockwise is the correct direction for the engine/crank. Crank bolt should be plenty tight as he was effectively tightening that as well.
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight
Old 07-09-2020, 03:35 PM
Tom Vaught's Avatar
Boost Engineer
(I READ IN HIS POST THAT INITIALLY HIS NEPHEW WAS NOT TURNING THE ENGINE CRANK IN A CLOCKWISE ROTATION SEE QUOTE BELOW)
After about 8 1/4 revolutions I realized my (nephew) never was turning it clockwise.
Tom V.
Old 07-09-2020, 03:43 PM
lust4speed's Avatar
... Crank bolt should be plenty tight as he was effectively tightening that as well...
Actually counter-clockwise would be the direction to loosen it, but if nephew exceeded 160 foot pounds turning over engine there would be more serious problems than a loose bolt.
Mick Batson
Old 07-09-2020, 05:01 PM
leeklm's Avatar
Tom V.
My bad, I missed the word "never" in that statement...
Old 07-09-2020, 05:16 PM
Tom Vaught's Avatar
Boost Engineer
All is good leeklm, you bring a lot to this street forum.
Tom V.
Old 07-09-2020, 06:13 PM
64speed's Avatar
To be clear he was turning it over clockwise like a Chevrolet. I noticed after he had made about 3 revolutions and said no Pontiacs spin counter clockwise. We reversed course and everything seemed ok. Is it all good?
Old 07-09-2020, 07:24 PM
64speed's Avatar
Never mind this. Trust me I just realized how big a dumbass I am. Distributor turns “backwards” not the engine. I told you I had TBI. I just had counter clockwise on the brain and panicked when I saw him
Old 07-09-2020, 08:26 PM
Tom Vaught's Avatar
Boost Engineer
Chevrolet Engine Distributor Rotors rotate CLOCKWISE when the crank is also turned clockwise..
Pontiac Engine Distributors rotate COUNTER-CLOCKWISE when the crank is also turned clockwise..
There is no backward or forward on distributor rotations.
You are not stupid. You just do not have much experience with Pontiac Vehicles and vehicle parts and that lack of knowledge is further hampered, you say, by your TBI.
Just keep trying.
Tom V.
Thread Tools
Display Modes
