Old 07-12-2020, 05:45 PM
Red Box Rebel Red Box Rebel is offline
Default 68 GTO LED Dash Lighting
I currently have my entire Dash and the dash components removed awaiting a new Dash Harness and new printed circuit board.
I plan on replacing all the number 194 bulbs and the remaining bulbs since all are over 50 years old. I am seeking input from anyone that has replaced the 194 with an LED bulb.
Is the LED illumination better? Is it worth the added expense?
If the LED bulbs are installed, are there any other electrical requirements needed to ensure proper operation?
1968 GTO Factory A/C, AM/FM Stereo Radio, Rallye Clock, Dash lights without gauges.
Old 07-12-2020, 09:53 PM
OG68 OG68 is offline
Make sure they're good quality LEDs that can be dimmed. Also just replace the illumination bulbs but leave 194s in the warning and signal lights. I read somewhere that the Delco charging system require the small amount of resistance in the incandescent bulbs to operate correctly. Since LEDs are polarity sensitive, test for proper operation before reinstalling the dash. If an LED doesn't work, just turn it 180* and try again.
2007 Cadillac SRX
Old 07-12-2020, 10:50 PM
THANK YOU!
Thread Tools
Display Modes
