Old 07-12-2020, 09:15 PM
racerx23 racerx23 is offline
Default 70 trans am wiring harness HEATING UP
A buddy with a 20,000 mile 1970 Trans am is having underhood wiring harness issues.The harness from the firewall to the coil is too hot to touch. Bad coil maybe ?? Any help would be awesome.
Thanks in advance
Steve Thomas
Dallas, GA
1950 Chevy truck red/original drive train
1967 Camaro SS silver w/black stripes 8.91@153mph
1969 Camaro SS 350 white w/black stripes
1971 Firebird 350 matching #'s white/blue int.
1975 Trans Am Blown 509 blk.
1975 Trans Am 400 matching #'s silver,loaded
1979 Trans Am 301 matching #'s,black
1980 Trans Am 301 matching #'s,t-tops,blue
1982 Mitsubishi drag truck 383 sb runs 9.92@ 133mph
Old 07-12-2020, 10:18 PM
Bill Hanlon's Avatar
If stock, somewhere in that circuit is a piece of "resistance wire". Takes the place of a ballast resistor. It will run hot. High performance coil will make it even hotter.
Old 07-13-2020, 10:34 AM
"QUICK-SILVER" "QUICK-SILVER" is online now
The resistance wire Bill mentioned is where your harness is heating up.
Is the engine running like it's suppose to?
Under what conditions are you feeling of the wires?
Point distributor or electronic?
A narrow point gap will make the resistance wire get hotter than normal with engine running.
Key 'on', engine off, points closed... And the resistance wire can get smoking hot.
Key 'on', engine off, points open... The resistance wire shouldn't heat up at all.
Clay
