Old 03-19-2016, 06:55 PM
6567GTO's Avatar
6567GTO 6567GTO is offline
Do you still have the upper door panel stainless trim set? 4 pcs.
Old 03-19-2016, 08:58 PM
Terry Gartner's Avatar
Terry Gartner Terry Gartner is offline
How are your vent windows?
1964 GTO Auto
1970 GTO Ram Air III 4-speed
1972 Lemans Convert with endura option, 455, 4-speed
Old 03-20-2016, 09:40 AM
RA6T7GTO's Avatar
RA6T7GTO RA6T7GTO is offline
Send a message via AIM to RA6T7GTO
I will try to look today
1967 RAM AIR GTO 1 OF 156 AUTOMATICS
Old 03-20-2016, 09:41 AM
RA6T7GTO's Avatar
Car I had was a post coupe,do you need just the glass or complete setup
Old 03-20-2016, 12:48 PM
My car is a hard top. I don't believe the frames are the same. But the glass may be. Is it softray or clear. I could use one side glass (my window frame is a bit rusted).
1964 GTO Auto
Old 03-20-2016, 02:21 PM
nyciti nyciti is offline
what about the trunk lid and rear tail panel w/tail lights and rad support.
Old 03-20-2016, 07:03 PM
Tom Vaught's Avatar
Boost Engineer
I would like to have the 64 Door Hinges Upper and Lower both sides if available
Tom V.
Old 03-23-2016, 06:33 PM
RA6T7GTO's Avatar
Glass I have would be clear,which side do you need
Old 03-23-2016, 06:34 PM
RA6T7GTO's Avatar
Tom V.
Hey Tom I should have some hinges,,give me time to look
Old 03-23-2016, 10:17 PM
Ron Landis's Avatar
Question So...
what condition are the frames in and how much? Wouldn't need the glass.
Old 03-23-2016, 11:39 PM
Dick Boneske's Avatar
How about the in-dash radio speaker support brackets? Speaker not important.
Do you have any of the trim clips from the strip at the bottom/back of the deck lid? There are six with studs and two with 8-32 screw holes.
Do you have the deck lid stainless trim strip?
ID:	424367   Click image for larger version
ID:	424368   Click image for larger version
Name:	64 GTO Deck Lid Molding Clip.jpg
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 03-24-2016, 06:04 AM
Thanks, I'm soft ray, can't use the clear.
Thanks for checking.
1964 GTO Auto
Old 03-24-2016, 11:34 PM
pestwagon64 pestwagon64 is offline
Default 1964 tempest
have the trim strips for the rear panel ( 1/2 inch thick) on the bottom?
Old 03-25-2016, 05:54 AM
6567GTO's Avatar
Got the parts Paul, thanks.
_________________________
Sonny Barger
Old 03-26-2016, 02:19 PM
Again I'm asking about the rear panel trim for the Tempest. Not the one in the center that goes across about 2-3 inches thick, but the narrow 1/2 in strips that border those pieces...
Old 03-26-2016, 04:22 PM
Tom Vaught's Avatar
Boost Engineer
look
No rush just looking for a spare set for the Tube Chassis car.
Tom V.
Old 03-28-2016, 12:58 PM
6567GTO's Avatar
I would send him a P/M guys.
  #38
Old 03-28-2016, 10:35 PM
RA6T7GTO's Avatar
Sorry guys been real busy,I will look as soon as I can for all parts,call me on Saturday's 631 978 8378 or text is fine
  #39
Old 04-02-2016, 08:37 PM
RA6T7GTO's Avatar
i cant find any brackets for the speaker yet, i will continue to look, no hardware for reat trunk lid chrome,i do have the stainless trim in very good condition if you needed that
  #40
Old 02-10-2017, 05:37 PM
ryan389 ryan389 is offline
Default 326 MOTOR
HOWS THE MOTOR?
DID IT RUN, AND,OR DOES IT RUN NOW.
IS IT FREE, NOT LOCKED UP.
HAVE ANY PICTURES, AND WHAT DOES IT COME WITH.
AND HOW MUCH.
PM THE PICTURES TO MY PM
THANKS
