Old 09-12-2016, 02:17 PM
judger69's Avatar
judger69 judger69 is offline
Default Ram Air 3 exhaust manifold dates
I did a search but could not nail this down.
Are all the original 1969 & 1970 RA 3 exhaust manifolds date coded? I've seen lots go by on ebay claiming to be original, but no date codes. The repops are starting to look pretty close. It sure is buyer beware on evilbay so I've been educating myself on stuff (mostly though this forum) but have read different opinions on this. Some say they shouldn't have a GM3 over the casting code, but I have a GM4 on my original 4234 intake.
Any insight?? or even pics of originals?
Thanks in advance.
Name:	nos 1637 3.jpg
Old 09-12-2016, 03:58 PM
unruhjonny's Avatar
I can check for you;
IIRC the passenger side manifolds are the same between A & F bodies;
The driver side one has a small relief in it for the F body, but I have put the A body one in my car in the past.
I have two or three spares hanging in my garage to check...
1970 Formula 400
Old 09-12-2016, 05:06 PM
Gordon Church Gordon Church is offline
The repro's are based on the 69 design the 70 manifolds only have three mounting bolts and are definitely date coded
Old 09-16-2016, 01:34 PM
judger69's Avatar
Johnny - thanks - I'd be interested in seeing what you have. I always thought the firebirds had more of a long branch header on the R/A 3's. Maybe I'm thinking first gen birds.
Gordon - didn't know that about the 3 mounting holes on the '70's. That and the date code makes it easy to spot a '70 as I think they share the same casting numbers as the '69's.
If anyone has some info they'd rather not share on here, I'd appreciate a PM too.
Thanks to all !
Old 09-16-2016, 02:13 PM
unruhjonny's Avatar
long branch are definitely 1967-1969 Firebird.
Second Gen Firebirds essentially uses the 1969 GTO manifold.
I don't know if I have your contact numbers, but if you have a smartphone, please PM me your number, I can shoot you several pictures of my loose RA manifolds.
1970 Formula 400
Old 09-18-2016, 01:03 PM
3goats's Avatar
3goats 3goats is offline
judger69
i have a set of 69 originals off the engine(judge ra 3) that I can snap picks for you and post.
Old 09-18-2016, 07:50 PM
Beige1968GTO Beige1968GTO is offline
Default For what it's worth in 1968 . . .
For what it's worth, the 1968 HO GTO I have (with essentially the same type manifolds as '69 RA III manifolds) has date codes on both. So if they used date codes in 1968 and 1970 its likely a safe bet to say they did in 1969.
Ron
Old 09-19-2016, 07:00 AM
Have you seen the banner above the thread for Pypes and Max teeming up for Max manifolds?
(it rotates so ad may not be there every time)
Looks like they are selling RA manifolds?
Old 09-19-2016, 12:08 PM
judger69's Avatar
Yes I saw them John, I already have a very nice set of 1968 R/A manifolds but again no date codes so likely repops ?? The one driver side stud was very close to the Upper Control Arm so I am looking for a set of originals. Most everything else on this car is date coded correctly.
And Ron - I agree it makes sense if the 68's and '70's are date coded the '69's should be as well. Its just that there have been so many go by on Evil Bay that are claimed to be originals ( Isn't everything on ebay? LOL !) but are not dated. If its just that easy as no date code = not original then I should be able to find that here on PY but an exhaustive search didn't tell me for sure.
That's why I threw this out there.
Thanks again to all !!!
Old 09-19-2016, 11:56 AM
judger69's Avatar
Originally Posted by 3goats View Post
judger69
That would be great Glenn, thanks !! Are you going to the High River show this weekend? A couple of us from here are making the drive on Sat.
I'm hoping to get some pics of the Mint Turquiose '70 Judge with red guts that was there last year. Ill see if I can post them.
Dion
Old 09-19-2016, 01:19 PM
unruhjonny's Avatar
iirc the originals are quite distinguishable from repops - as the repops are of much higher quality, and often used 3 bolt head pipe flanges, where the originals would often be 3 & 2 bolt flange.
I do believe that the presence or absence of a date code is a key way to discern if it's a repop - I do not believe any repop manifolds (intake or exhaust) have date codes - but I might be wrong.
1970 Formula 400
Old 09-22-2016, 02:03 PM
judger69's Avatar
Default Anyone ??
UnruhJonny, thanks for the pics of the late 1969 cast 3 mounting hole manifolds.
Anybody out there with an original late 1968 or early 1969 cast 5 bolt hole ram 3 exhaust manifold that does not have a date code cast onto it? No pics necessary just want to know if they were ever done that way.
Old 09-23-2016, 01:39 PM
3goats's Avatar
Hey Dion
I didn't here about a car show in High River? Maybe I should run up there Sunday and check it out.
I will get those pictures of those manifolds for you tonight when I get home. I just got busy and to be honest I forgot! LOL The engine is on a stand in my shop covered up and I walk pass it everyday so you'd think it would of reminded me..
Any ways i'm workin on it and post them the next day
Old 09-23-2016, 01:51 PM
judger69's Avatar
Hey Dion
Yeah Glen, its usually a good one. Last year there was somewhere around 1000 cars but the weather was nice. There were a few nice GTO's there. I forgot it was Sun not Sat.
No worries on the pics man. Im really not in a hurry. I still haven't installed the flywheel I bought from you or put my engine in yet .
Old 09-23-2016, 02:11 PM
judger69's Avatar
Default Claimed original no date 1637
There is a 1969 WS engine right now on Evil bay claimed to be original from carb to pan never rebuilt. No date code on the 1637 exhaust manifold. It also has the GM3 above it. I am confused now. This car was on the road for 11 yrs, engine never rebuilt. It is possible the manifold was changed, but..........
Ebay link. You can zoom in better.
http://www.ebay.ca/itm/1969-GTO-Judg...3D122091378318
Old 03-31-2024, 03:38 PM
steve@tru-built.net steve@tru-built.net is offline
Default Exhaust manifolds
I'm currently rebuilding the engine in my 68 Pontiac Firebird. The car has been in my family since 1972. My grandfather purchased it from his boss who purchase it new. It's mostly original with 68K miles and numbers matching. It's a 320 HP 350 H.O. with 4-speed car. I'm thinking about upgrading the exhaust manifolds. I don't want to go with header if possible. I'm thinking about installing a set of Ram Air III manifolds. I found a set on Ebay, but they're for 68 and 69 GTO. Does anyone know if these will work on a Firebird without issues?
Thanks,
Old 09-23-2016, 03:45 PM
unruhjonny's Avatar
FYI
http://rivercityclassics.ca
1970 Formula 400
Old 09-23-2016, 09:46 PM
rotted off
Old 09-24-2016, 01:27 PM
judger69's Avatar
Originally Posted by Gordon Church View Post
rotted off
I wondered that too Gordon, but the date location of the 478140 (1970 equivalent to the 1637) is right where the GM3 would be. Perhaps the 1637 in my last picture had the date somewhere else? I have never seen a date on a 1637.
Perhaps someone could confirm or deny the date location of the 1969 DS 9791637 manifold. That would be helpful.
Thanks everyone.
Old 09-24-2016, 01:33 PM
judger69's Avatar
Default Date code location of a 1970
Thanks to Unruhjonny for this picture of the date code on a 478140. It is right where the GM3 was in my previous posts (including my first post of this thread). Could the date code be in a different place on a 9791637 ? I have yet to see one.
