Old 12-10-2020, 12:29 AM
jimib's Avatar
jimib jimib is offline
Today, I had time to trace the two wires connected to the POSITIVE terminal of the battery. One goes to the electric choke (on the carb) and the other red wire (thicker) goes to the engine side of the fuse box, On the interior side of the fuse box, I don't know where this thicker red wire goes. I'll try to figure this out the next chance I get.
The 1st pic shows the choke, the 2nd pic shows the fuse box engine side, the 3rd pic shows the fuse box interior side.
1967 GTO, hard top, 400 Block, Butler Performance Build, EFI Holley Sniper, Tremec 5-Speed, Moser 373 Rear, 4 Wheel Disc Brakes
  #42
Old 12-10-2020, 12:32 AM
jimib's Avatar
PIC 2 and PIC 3
ID:	555767   Click image for larger version
  #43
Old 12-10-2020, 12:37 AM
ID67goat's Avatar
ID67goat ID67goat is offline
If the choke is wired directly to the battery and not through switched power that could be what is drawing your battery down as it will be supplied with power all the time.
The other red wire....not sure on that one. Make sure you check where that wire is going to.
  #44
Old 12-10-2020, 01:09 AM
george kujanski's Avatar
george kujanski george kujanski is online now
Agree on the choke wiring...should be wired to a circuit that is live only when the ignition is on.
George
  #45
Old 12-10-2020, 03:58 AM
Old Goat 67's Avatar
Who wired that American Autowire stuff in? You?
Do you have wiring diagram on how it was done?
