65 2+2 vert 421 HO update: Were should I expect to find the build sheet??
So were should i expect to find the build sheet?? No luck yet! I do still have the Console in the car and may find the sheet under the last bit of carpet just under the console.
I've pulled the front and rear seats, carpet, underlayment. The Front foot well sheet metal is perfect still having factory paint with no rust. Not so lucky in the rear foot wells, two holes about 3/4" Dia. on one side and about a 1 1/2 hole in the other. Brian |
Under the rear seat bottom is where the guy found the one for my car. I also found a partial sheet wedged in the dash metal right above the radio. That was tricky to get out but it came out in one piece.
Should you ever find yourself the victim of others peoples bitterness, smallness or insecurities, just remember, things could be worse. You could be them. Check out my sons blog, www.driftundertheradar.com |
The one in my 66 was on top of the gas tank.
The difference between inlaws and outlaws? Outlaws are wanted |
Under the trunk mat is another place.
Just recently found one up in the headliner.
"If you do everything you'll win" -LBJ 13 Smiles per Gallon: 66 Bonneville wagon 66 Bonneville 2d HT - In perpetual progress |
