Old 10-06-2007, 06:57 PM
bej's Avatar
bej bej is offline
Default 389 +.060 or 400 standard pistons
I'm looking for 389 +.060 or 400 standard pistons. Dished for a 9.5 to 1 compression or lower rebuild. My machinist said he could machine a dish in a set of flat top pistons but that would cost me another $150.00. I Checked with the big guys (Summit & Jeggs) and it sounds like the Keith Blacks are on back order.
Any ideas?
Thanks!
bej
Old 10-06-2007, 08:50 PM
Blue '66's Avatar
Blue '66 Blue '66 is offline
I would post a wanted ad here for the pistons.I bought a set of 60 over 400 forged pistons here,slightly used and balanced!Worth a shot.
Old 10-07-2007, 01:04 AM
Will Will is offline
Keep in mind the heads and cam you will be using. 389s had a different valve angle than 400s did, thus the valve reliefs in the pistons are different. If you will be running a high lift cam this could be important.
Old 10-07-2007, 06:10 PM
engineer engineer is offline
just dish the standard 400 forged pistons and then don't worry about the valve reliefs. dishing will remove reliefs.
Old 10-07-2007, 06:59 PM
Tom Vaught's Avatar
Boost Engineer
I ran a 400 std piston on my 389 engine and checked the cam lift vs the piston position with a .590 lift camshaft. I still had lots of P/V clearance.
I really doubt if you would even come close to the piston with a stock camshaft and if you did a dish on the 400 piston, (lots of meat there) you would probably be very safe with even a high lift camshaft.
Tom V.
Old 10-07-2007, 08:39 PM
bej's Avatar
bej bej is offline
Any ideas as to were to find a set of above said pistons?????
Old 10-07-2007, 09:37 PM
Tom Vaught's Avatar
Boost Engineer
I might have a spare set on the shelf of new ones but they can still be bought. Mine are pretty dirty and the box is pretty old but I kept them as back-ups for my 389 engine.
I really do not want to part with them. They are out there.
Tom V.
Old 10-08-2007, 10:34 AM
Mr. P-Body Mr. P-Body is offline
Yup, I know EXACTLY where they can be bought! That is, here or most other engine building shops in North America! Not rocket science. A "simple" dish is all that's needed. $150 labor to do that is about double what the job takes. Unless they're the new forgings, it's a GOOD thing, KBs aren't available. Get Speed Pro L2262F (std.) and dish them, and be done with it!
One thing to watch for: some 389 crankshafts have fatter counterweights than others, and can interfere with the piston skirt. This isn't usually a problem, but it must be "checked".
Jim
