Old 11-24-2007, 11:32 AM
bej's Avatar
bej bej is offline
Default Correct timing cover for my 64 GTO
Looks like i managed to send out the wrong timing cover (1968 only part number 9790347 takes the 8 bolt water pump, Has the Water neck hump, but from my search results it takes a larger Balancer???) with my 1964 78X GTO engine and it came back with the assembled engine installed and all sealed up but not water pump installed and I still need to buy a new balancer.
So If I wanted to run a stock 64 balancer and pulleys I would need to install the correct timing cover part number 9773371, Which I have here on the bench.
Also, I will be installing a tripower on the 78X motor.
Right or ???
Brian
Old 11-24-2007, 02:43 PM
Andre's Avatar
Andre Andre is offline
I have the right timing cover for your application. email me if interested. Note that it has the single pointer.
Old 11-24-2007, 06:17 PM
bej's Avatar
bej bej is offline
Well thanks, but like i said above i have the correct part numbered piece on the bench.
My Question was: Will the 68 only unit i have installed work right with all the 64 balancers and pulleys.
Thanks,
Brian
Old 11-27-2007, 03:40 PM
mth mth is offline
Yes I beleive you are correct, it is my understanding that the 64-68 is the same cover 8 bolt water pump. I am putting a 69 timing cover on my 64 with the 11 bolt water pump with the flow cooler pump for better cooling and will have to use a different damper and pulleys.
