Old 12-02-2007, 11:36 AM
bej's Avatar
bej bej is offline
Default 65 2+2 421 HO Convertible Question
Hey guys,
I'm trying to figure out if my car was an original eight lug wheel car. I have the PHS report but it does not plainly list what type wheels came on the car.
Is there a code on the order card that denotes this?
Same Question for the rear end and axle ratio. I have a VF code (3.23 I believe) axle housing in place in the car and I think that a Safe-t-track rear end would have been mandatory on the 421 HO equipped cars like mine????? What say you?
Is there a code on the order card that denotes the rear end and Axel ratio?
Thanks,
Brian
Old 12-02-2007, 11:50 AM
65WJ's Avatar
65WJ 65WJ is offline
I think, space 71 on the punch card denotes the code. Mine is VJ which is 3.73 and my code is 9
Safe t track was an option. The first letter, in our case "V" denotes safe t track the second letter refers to the ratio.
Re read GNX ranch post on his.
I will check my manuel and see if 9 relates to vj
Patrick
Old 12-02-2007, 11:55 AM
bej's Avatar
bej bej is offline
Thanks Patrick,
I'll dig out the PHS and take a look........then repost.
Brian
Old 12-02-2007, 12:26 PM
bej's Avatar
bej bej is offline
After looking a little closer i see that line 69 on the order punch card is listed as Aluminum wheel hubs and drums but i do not have a code number in that box.
So does that mean that my car did not come with eight lug wheels??
Also i see that box 70 is for axle type. There are three listed on the order sheet
Code 1 is listed as "Safe-T-Track
Code 4 is listed as Economy Axle
Code 8 is performance Axle
I do not have any of these codes in the number 70 box on my punch card???
Seems odd. Are you sure the Safe-T-Track was not mandatory with the 421 HO option?
Old 12-02-2007, 12:50 PM
Hitman's Avatar
Hitman Hitman is offline
You would think it was. The only real way to check is to jack it up and scrape off the years of muck off the passenger side axle tube about 6 in off the cover and get that code and hope it starts with a V. A lot of 2+2 came with the standard steel wheels and hub caps though. Not unusual. Most got converted over the years though.
Should you ever find yourself the victim of others peoples bitterness, smallness or insecurities, just remember, things could be worse. You could be them.
Check out my sons blog, www.driftundertheradar.com
Old 12-02-2007, 01:22 PM
65WJ's Avatar
[QUOTE=bej]After looking a little closer i see that line 69 on the order punch card is listed as Aluminum wheel hubs and drums but i do not have a code number in that box.
That is correct. No 8 lug wheels for me either. I have the spinner hub caps.
On your punch card "70" does not have a number?
I still cannot find my manual. dang it.
patrick
Old 12-02-2007, 01:41 PM
bej's Avatar
bej bej is offline
[QUOTE=65WJ]
patrick
That is correct. Nothing in the box at location 70 on my punch card.
I can see were the 9 in your box 70 would add up to 8 + 1 =9 or #8 Safe-T-Track + #1 Performance Axle of 3.73 = 9 in box 70 on punch card.
But why is my box empty?????
My box number 52 is empty also. I see if you have a number 1 in it you had custom wheel covers. Are those the "Spinners"?
Brian
Old 12-02-2007, 02:03 PM
bej's Avatar
bej bej is offline
Patrick
After reading the post by GNXranch I see I must of had a 3.23 open rear end.
I have no codes in boxs 69 or 70 and in 71 I have a 6 which would be a letter F for 3.23
Old 12-02-2007, 02:09 PM
safey trac was an option on all cars. to my knowlege it's never been std equipt on a production model.
in later years the code on the line sheet is g-80 across the line for gm.
mike
former." --Albert Einstein
- Winston Churchill
Old 12-02-2007, 02:19 PM
65WJ's Avatar
Brian
Box 52 on my card has a 4 "custom sports steering wheel" aka wood wheel.
I think the custom wheel disc were the wire hubcaps. I will double check.
patrick
Old 12-02-2007, 04:52 PM
bej's Avatar
bej bej is offline
Brian
patrick
So what wheel covers would have been standard on the 2+2 if you did not have any of the optional choices???
Pics would be great!
Brian
Old 12-02-2007, 06:04 PM
stevensonDNL's Avatar
stevensonDNL stevensonDNL is offline
I'm looking at my Billing History Card and code "1" appears column 69, which indicates "Aluminum Wheel Hubs & Drums" per the "1965 Model Wholesale Car Order" form. Also, I have a code "1" in column 70, indicating "Safe-T-Track Rear Axle", and code "7" in column 71 ( I don't see a column 71 on the "1965 Model Wholesale Car Order" form). I know for a fact from counting the actual gear teeth and by the stamped code "VG" on my passenger side axle tube that I have a 3:42:1 differential.
Old 12-02-2007, 06:29 PM
Bej: According to the dealer sales catalog, Safe-T-Track is listed as an available "Safety" option as opposed to a "Performance" option. According to my '65 Pontiac Chassis Shop Manual, Rear Axle section 4, page 5, the rear axle chart shows the following standard releases for a 421 H.O. Tri-Power equipped Catalina 2 + 2 Coupe or Convertible: 3.08 (E) with Hydramatic and Air Conditioning. 3.23 (F) for Hydramatic w/o Air Conditioning. 3.23 (F) with 3 or 4 speed Synchromesh and Air Conditioning. 3.42 (G) with 3 or 4 speed Synchromesh with or without Air Conditioning.
A 3.55 (H) was a special order with any transmission without Air Conditioning. 3.73 (J) and 4.11 (L) were also special order ratios.
Dan
Old 12-02-2007, 06:30 PM
bej's Avatar
bej bej is offline
Sounds like the 7 in Column 71 would line up with "G" in the alphabet. Since I have a 6 in my box i must have had a peg leg "F" 3.23.
I am glad the previous owner went to the trouble to find a VF code axle years ago after the original went out.
Brian
Old 12-02-2007, 08:11 PM
stevep's Avatar
stevep stevep is offline
I think that the Custom Wheel Discs are the spinners. The Deluxe Wheel Discs are the basic full hubcap and I think, were standard on a 2+2.
Thread Tools
Display Modes
