Old 10-16-2020, 08:42 PM
ta man ta man is offline
Originally Posted by 77 TRASHCAN View Post
Hope maybe you can squeeze one more teat date in...this year...
As long as the weather co operates..both carbs next time I go.
  #322
Old 10-16-2020, 08:51 PM
MUSLCAH MUSLCAH is offline
Good read......hope you get that 10.60
  #323
Old 10-19-2020, 02:30 AM
Will Will is offline
Love this thread and your car.
Unfortunately, it's been awhile since I've tried to catch up on it all and there are just too many posts to read through them all.
Maybe I'm hallucinating, but I thought you were thinking of changing the rear gears. Do you still have the 3.08s back there?
The Following User Says Thank You to Will For This Useful Post:
  #324
Old 10-19-2020, 01:00 PM
Yes still the 308's.
  #325
Old 10-19-2020, 04:51 PM
77 TRASHCAN's Avatar
After hearing you mention that crazy 60 foot time that Andy had, recently...it would seem like you've still got possible improvements on your 60' time (I know you've got the lower gear in the trans...). Hope your weather holds good, for a little longer. Supposed to maybe have first freeze, here in central Oklahoma around election day...
Shut it off
Shut it off
  #326
Old 10-19-2020, 05:25 PM
Yes that is the current focus is dropping the 60 ft..winter is coming so also planning a few changes for next year.
  #327
Old 10-20-2020, 01:41 AM
Awesome. Keep the faith!
you give me hope for someday running a decent time with my 3.23s. Or maybe I'll swap to 2.73s and just forget the whole overdrive trans thing.
  #328
Old 05-26-2021, 09:38 AM
I figured I would add to this thread with an update and a finding. Anyone that has followed this thread will have noticed the ProSystems carb could not 60 foot with the Holley. Not once did it go under 1.6 compared to 1.55s with the Holley.
So one of the golden rules of tuning is check for full throttle..some how this guy missed the memo. So my carb did have full throttle..but it was taking approximately 2 seconds to achieve it...due to the secondary accelerator pump arm hanging up on the rear pump cam. I discovered this a few nights ago when I was investigating why my pedal felt so stiff and has felt stiff.
This must explain why the car picked up time dropping the shooter size way down because the car was only leaving with maybe 700cfm available upon the hit..but never went under a 1.6 time.
  #329
Old 05-26-2021, 11:55 AM
AG's Avatar
AG AG is offline
Note to self, check everything. Good find.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
