#41
#42
Here's the fastest timeslip.
#43
"When the cam arrived I had to sign for it, open the tube with a secret code, the cam card had ink on it that disappeared after 5 minutes."
That is classic, loved it I'll take a stab... Magnum lobe 3122B 289 236 160 .3800" XE lobe 3196B 287 236 162 .3910" .
#44
I should have added it was written in Canadian!
#45
Hey Ernie it was good to get out together this year finally.....
It was a beatutiful day to be at the track ...nice weather little bit of a breeze..ran 12.24 best for the day and best 60 for me too..... Yep was a good day at the track....Ernie's car flat out moves..... Andy we gotta get out there the three of us......before the season is done.....
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's |
#46
Ta man, without wading through everything, what size is the intake valves in your heads?
#47
intake 2.11 Exhaust 1.77.
#48
#49
LOL, Pontiacs don't need nitrous to run 10's. The poor guy's brain likely froze up when you told him you were running 3.08 gears...
So Chris, any future power upgrades planned for your engine? Where was Andy? Ernie, what exact tire do you run?
#50
If interested here are reported flow numbers for a set of Dave Bisschop KRE D-port 82cc 300-305 CNC ported heads / 2.110 & 1.770 valves w/ 45 degree seats. Note, these numbers are from 2010 and they might be similar to Ernie's current '305' heads, but that would be a guess on my part. Numbers from one cylinder tested at 28 inches. No intake runner volume reported.
Intake: .100 74.7 .200 148.4 .300 211.4 .400 260.1 .500 290.4 .600 304.3 Exhaust: .100 68.5 .200 127.2 .300 167.1 .400 195.4 .500 218.9 .600 231.5 Average exhaust-to-intake flow ratio thru the lift curve is 78 percent. And my stab at the current exhaust lobe in use from the information within the link I posted, it's Magnum lobe 3123B with 246 at .050" and .4000" lobe lift. And the obvious, the intake cam specs I mentioned previously were the regular Old Faithful vs the revised OF 2.0 version. These lobe numbers are right from the Comp Mater Lobe Profile Catalog. .
#51
One advantage to solid cams is the ability to tweak lash and let an engine tell you what it really wants. Without that feedback, 10 degrees extra .050 duration on the exhaust seems to be a common default. |
#52
Shift rpm?
#53
5800 or so..it may like 6000 to 6200
#54
"5800 or so..it may like 6000 to 6200"
If it helps, proven dyno numbers for a similar combo. But 4 degrees less intake duration. 455 .030 over 4.250 stroke KRE 300/305 d-ports CNC port matched torker II / HP950 carb 246 degree hydraulic roller / 112 LS 593-600 ft.lbs. Tq / 4600-4700 (peak) 589 hp at 5800 rpm (peak) .
#55
And the lifts and durations were metric?
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust My webpage http://lnlpd.com/home |
#56
About 0.016764 meters gross valve lift with his Harland Sharp rockers
0.660" Works very well the heads that will continue to flow past 0.600" lift. .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) 5.14 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 08-27-2017 at 06:24 PM. |
#57
#58
I guess its time to finally install my shiftlight..since my factory tach only goes to 6000rpm.
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 Last edited by ta man; 08-28-2017 at 01:26 AM. |
#59
Ouch, I just noticed a BIG mistake I made in conjunction with the combo mentioned in my post #54. The cam used had 10 degrees more intake duration than the OF 2.0 here ! Obvious mistake as I stated it had 4 degrees less. It made peak power at 5800 rpm with a 246 degree hydraulic roller cam. I should also point out It used solid roller lifters which would have a tendency to raise the peak rpm a bit.
Sorry for the confusion. Here was testing by Dave previously with less cylinder head and the 'regular' OF cam, from his web site.... " We decided to do some intake manifold comparison testing on a 474ci engine running a set of our 290cfm CNC ported KRE D-port heads with 10.2 to 1 compression on 91 octane fuel with a 236/245 duration hyd. roller cam. Torker II has a square bore plenum so we installed a 950HP Holley on top of it with a 1" open spacer for the last test. The Torker II didn't disappoint and produced 554hp @ 5500rpm and 584 lb ft m. @ 4500 rpm. " .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) 5.14 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 08-28-2017 at 07:59 AM. |
#60
