Old 08-29-2017, 12:59 AM
Will Will is offline
Originally Posted by ta man View Post
I guess its time to finally install my shiftlight..since my factory tach only goes to 6000rpm.
I think I have a factory 8k tach you could have for cheap... 😉
  #62
Old 08-29-2017, 09:19 AM
Steve C. Steve C. is offline
Related. Hard to trust tach readings unless verified, "6000" rpm on a factory tach could well be 5500 actual. I have a AutoMeter tach mounted in my dash and recently found it inaccurate while installing my new port fuel injection system. Found out while programming the ECU when the program readout indicated the tach was reading low.
Old information here:
  #63
Old 08-29-2017, 11:25 AM
stickboy's Avatar
stickboy stickboy is offline
Peg that needle and shift!!!
Nice 60' times for your setup too
very impressive converter/gear performance
65 GTO, 3800#, 474, KRE Dport 330 cfm, 11:1 on pump gas, XE 242 248 solid roller, T56 trans, 3.90 gear, 11.26 @ 124 mph
  #64
Old 08-29-2017, 12:08 PM
ta man ta man is offline
I figured out that a few years ago my tach reads about 300 rpm high over 5000 rpm.
  #65
Old 08-29-2017, 12:19 PM
Thanks ! The 15 year old Continental still works well. I think this is now the 4th engine combo it has been behind. I know I've been tempted in the last few years to swap to a 3800 to 4200 stall convertor and 3.42 gearing..but this is too much fun!
  #66
Old 08-29-2017, 01:57 PM
77 TRASHCAN's Avatar
Maybe you can test one of the units that Cliff is now selling, and report back to us. I'd buy your old one...
Shut it off
Shut it off
  #67
Old 08-29-2017, 03:05 PM
PAUL K's Avatar
PAUL K PAUL K is offline
I used to shift mine after the second tach bounce...then had a custom stock looking 8k tach made... and built a 4" stroke engine so I could watch it buzz to 7200.
Go fast, see Elvis!
  #68
Old 08-29-2017, 10:43 PM
Took the car out tonight for a short drive came back checked idle turned it up slightly car idles between 875 and 925 rpm with 8 degrees timing,no advance.Pulls 12 inches of vacuum in park 10 inches in drive.Checked cranking compression in No 1 cylinder its 185.
  #69
Old 08-29-2017, 10:53 PM
surfsama's Avatar
surfsama surfsama is offline
Is the 8 for initial? What is your total?
I have to run 16 initial + 22 for my older E-Heads. The newer head chambers must be much more efficient.
Only a pawn in game of life.
  #70
Old 08-29-2017, 11:01 PM
31 degrees total,Yes the KRE chambers are known for low total timing most fall between 28 and 32.
  #71
Old 08-30-2017, 04:12 AM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
Same here. 18 initial 38 total.
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
  #72
Old 08-30-2017, 06:15 AM
highway star's Avatar
highway star highway star is offline
"canton 400 oil pan with an oil temp sender"
What's the ideal oil temp? And what brand/viscosity oil?
  #73
Old 08-30-2017, 09:44 AM
From what I have read I'm in a good range of 190 to 210 for oil temps.I ran a 10/40 dino oil on breakin for 150 miles. I just switched to 10/30 Synthetic which can see higher temps and not break down.
An added bonus with the oil temp gauge I can insure the oil is warmed up before a dragstrip pass.
  #74
Old 08-30-2017, 06:49 PM
leeklm's Avatar
leeklm leeklm is offline
Reading your break in procedure, etc, I predict that your motor will outlast mine
Sent from my XT1585 using Tapatalk
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight
  #75
Old 08-30-2017, 07:39 PM
I know the shortblock is well built..actually well built may be an understatement. I've never had ring seal like this shortblock has and it should maintain it. My last 2 engines you could always smell a bit of gas in the oil with my crappy tuneups. As much as I didn't like the idea of a hardblocked engine I'm really starting to see the advantages.
  #76
Old 08-30-2017, 11:00 PM
I've heard Jim Butler speak at least a couple of times at tech seminars at the Pontiac Southern National event in Dallas. He spoke of very favorable things that hard locking can do for an engine. This was likely pre 2001. His Pontiac knowledge and business sense were both outstanding. His boys have a lot to be thankful for. Their Dad set a top notch example for them to follow!!!
Shut it off
Shut it off
  #77
Old 08-31-2017, 10:49 AM
ponjohn's Avatar
ponjohn ponjohn is offline
How do you know this?
  #78
Old 08-31-2017, 11:07 AM
torqhead's Avatar
torqhead torqhead is offline
Curious, what type and size rear tire are you running?
  #79
Old 08-31-2017, 12:42 PM
Not sure I know what the question is?
  #80
Old 08-31-2017, 12:44 PM
Currently M/T ET Pro 275/60/15.
