#81
In the RA III 400 that we just built with the 2802, we used the standard A-0951 Hylift-Johnson lifter that we purchased from Paul K, a member here, he is a dealer. They are quiet as a mouse so far too, no signs of any kind of ticking, even on the initial startup, but we did pump the engine up before we fired it. The last thing a person wants to do is lose a lobe during break-in due to an inferior, soft, offshore lifter. That's makes for alot of expense and headache over buying the better lifters the first time around. We also use a full bottle of Comp Cams break-in additive along with conventional Quaker State 10W30 to break in all of our flat tappet engines. After a 30 minute break-in, the oil and filter are changed, and we add another bottle of the Comp Cams break-in additive, until the first 3k mile oil change, after that its just the oil of customers choice, and no longer use the additive.
1978 Trans Am Pump Gas 461 Stroker Last edited by TransAm 474; 10-13-2020 at 10:24 PM. |
#82
cam
got joe gibbs break in 40 right now you recommend a bottle of that also?
#83
The extra additive isn't needed with the Gibbs break-in oil. It has plenty of additive already in it.
1978 Trans Am Pump Gas 461 Stroker |
#84
cam
10-4 ordered the 2802 with the jegs us lifters. still waiting for the valve springs from erson.. Jay helped with me with that mess I will check coil bind after install of cam, lifters and spring kit . peace
#85
Cool, sounds like your plan is coming together well. I will be following along...
#86
Just a tip
Called lunati to cancel my cam order . Got to talking with them and he stated as of now he has been waiting 2 months for 146 blanks to grind .his suppler told him probably January-February time frame he blamed it on the cam forging companies COVID shutdowns
Comp lifter |
#87
LOL I knew that was going to be the reason. Everyone blames the beer virus for everything now. It's getting ridiculous.
Maybe you'll have better luck with another cam company. Fingers crossed. |
#88
#89
springs
well I borrowed a install height mic and came up with 1.690
also found a spring weight tester and with the springs that are currently installed I checked them at the installed height of 1.690 and the compressed length of 1.200 124lbs at 1.690 294lbs at 1.200 not sure if im doing this correctly I made marks on some tape with a pen and a dial caliper from the base of the unit?? Last edited by Nyairguard; 10-14-2020 at 09:55 PM. |
#90
That figures out to be a 347 springs rate. Comps 995s are rated at 402. Springs vary on their pressure, if the test was correct that is on the low side for a Comp 995. More what you would expect from one of the comp 994 spring after some use.
You about have to check everything anymore, QC is all on the user end these days. 2802 should be a good cam. |
#91
springs
jay leave these in and send the others back??? no big deal to return what your thoughts?
#92
I would run them. I would check at least one more to see if they vary much.
#93
"...some have said that Delphi is supplying Comp Cams with their lifters nowdays."
Real easy to spot a Delphi lifter. Unless they have changed recently, they have a "hardened foot". Therefore, they will have a thin groove, very near the bottom, where the foot is joined to the main body. Problem is that you can't be sure that the lifters that you'll get in the box will be the same lifter that is pictured in an online ad. Sometimes the lifter pictured is not even close to the lifters you'll get in the box. Check out the pics for all these different lifters. Some have no grooves at all. Some have 1 groove above the oil band. Some have 1 groove just below the oil band. Some have 2 grooves just below the oil band. Then some show pics of the Delphi lifter, with the thin groove near the bottom. And, there are at least 3 different retainer types. But who knows what will actually come in the box. https://www.summitracing.com/search/...ic-flat-tappet |
#94
lifters from jegs
got these from jegs only a few sets left?? 60 bucks
#95
info?
see a ton of these 400 stroker kits out there,,
any of these work with high compression heads or you need big chambers? I have 76cc heads 10.06 comp just wondering for future build |
#96
Here's what I bought. But it's probably been nearly 2 years ago, now.
#97
https://butlerperformance.com/i-3164...tegory:1459543 You can buy 'em with 4", 4.21", 4.25" stroke & even bigger. https://butlerperformance.com/i-2445...tegory:1459542 Forged crank & Ross dish pistons cost extra. Most do NOT recommend an Eagle cast crank. https://butlerperformance.com/i-2459...tegory:1459542 How about a ready to assemble short block kit ? https://butlerperformance.com/i-2445...tegory:1234783 OR, if you live anywhere near OK, you might wanna consider a short block from Len Williams. I'm sure he can add forged crank & dish pistons, for an extra fee. http://lenwilliamsautomachine.com/455_Short_Block.html Last edited by ponyakr; 10-15-2020 at 06:34 PM. |
#98
Lifters
Big mistake by me not going with lens shop he was 3 months out and I should have just waited..lessen learned the hard way my azz still hurts. Cam should be here Saturday but gone with the air force till Monday
#99
Timing chain
I have the cloyes 3 key roller the advance slot with the triangle or A will be the 2 degree advance I’m looking for correct?
#100
Be careful messing around with multiple keyway timing sets. You MUST align the correct mark on the lower gear with the dot on the upper gear if you move it from the standard keyway. Most are well marked, Circles, Triangles, Squares for the 3 keyway variety. Early Rollmaster sets were not marked and they are confusing even when they are marked on each keyway. The instructions they used to send with them didn't help much either.
If memory serves me correctly if you move it from the "dot to dot" or zero position to another keyway you need to move straight up to the closest tooth, then back two to the left as the new point to align with the top sprocket mark. ALWAYS re-check ICL or the intake open point after each movement. The Cloyes iron sprocket 3 keyway sets and not really any sort of "upgrade" and they will stretch out pretty quickly from what I've seen here. Even the top shelf billet sets with the expensive imported double roller chains stretch out a pretty good amount if you are putting a lot of street miles on the engine. I knocked one clear out of my first 455 build in 4 years of daily driving and racing the car as many times as I could get it to the track every week.........FWIW.......Cliff
