#101
Chain
Ok cliff , first I’m going to install dot to dot and see where I’m at , looks like the 2802 has 4 degrees built in
The Following User Says Thank You to Nyairguard For This Useful Post: | ||
#102
key
ordered a Mr. Gasket Crankshaft Keys 987G in case I need one is the correct key?
some call it a cam key some call it a crank key?? what gives I never used one |
#103
On a pontiac, the factory crank uses a long key, instead of dual short keys like a chevrolet, so you will have to use it in the camshaft. Just be aware that the 987G key will advance or retard the cam 4 degrees. It is advertised as a 2 degree "crank" key, but when used as a "cam" key, it will be 4 crank degrees.
1978 Trans Am Pump Gas 461 Stroker |
#104
Cam
What you using if you want 2 the sprockets key?
#105
cam timing
Had a bit of time to check the 2802
IN open @.050 is 2 degrees card states 3 degrees BTDC IN close @.050 is 41.5 degrees card states 41 degrees ATDC should I make any adjustments? Im still waiting on the 2 degree key not sure if I need it???? |
#106
Stan
#107
cam timing
thanks Stan I will do what you sugest.
worth putting the 2 degree key in for more bottom or wont notice enough for the wait ? |
#108
cam timing
EX is 57.5 degree @ .050 card states 56 BBDC
EX is 1 degree @ .050 card states - 2 ATDC |
#109
Stan
#110
I get Intake 109.75 and exhaust 118.25 which is a LSA of 114. Stan
Stan Weiss/World Wide Enterprises Offering Performance Software Since 1987 http://www.magneticlynx.com/carfor/carfor.htm David Vizard & Stan Weiss' IOP / Flow / Induction Optimization - Cam Selection Software http://www.magneticlynx.com/DV Download FREE 14 Trial IOP / Flow Software http://www.magneticlynx.com/DV/Flow_..._Day_Trial.php Pontiac Pump Gas List http://www.magneticlynx.com/carfor/pont_gas.htm Using PMD Block and Heads List http://www.magneticlynx.com/carfor/pont_pmd.htm Last edited by Stan Weiss; 10-19-2020 at 01:03 AM. |
#111
Stan
#112
cam
thanks for all your help going back together as is ,, cant wait to hear it!!
#113
cam install
well I installed the 2802, must say it runs pretty good after break in.
good vac and a slight lope nothing radical didn't take a ride in it yet hope to very soon, little bit of lifter tick I'm running 1/2 turn past zero lash what you guys using for for preload I was gonna try 3/4 turn?? this is the method I used https://pontiacstreetperformance.com/psp/rockers.html Last edited by Nyairguard; 10-23-2020 at 11:09 PM. |
#114
Please give us some feedback on how it runs after you take it for a drive.
#115
lifters
I will definitely try that,, I had a spare and a quick bench measurement was .195 almost 200 thousand
seen this post If they're 7/16-20 then that's 20 threads per inch. So using simple division gives us .050" per thread (you simply divide one thousand by 20 threads, and you get 50 which represents 50 thousandths of an inch, AKA .050"). Therefore, one complete turn will yield .050" of inch. Your answer is one turn. :yes: And a 1/2 turn will yield .025" wonder how so many peeps are getting by with only 1/2 turn thats way too little?? |
#116
first ride
well finally got to take the car for a ride,
air temp 55 vac 14 inches 750 street demon running a bit fat timing 13 static, 21 mech, 10 vac (manifold) real slight lope at idle no-ping anywhere here are my initial thoughts of the 2802 compared to the 068 idle quality excellent lost 2 inches of vac was 16 now 14 no different in brake pedal feel power came on about 400 rpm further 068 would start pulling bout 2200 summit cam bout 2600 lost a slight bit of torque not at all an issue just give a little more gas I can definitely feel a power increase, made 2 runs at my favorite street with mostly farms and straight hardly no tragic first run dumped the clutch at 2800 or so no match for my 70 series radials shifted at just 5500 rpm and got some serious rubber 1-2-3 forth I was a bit chicken **** and and slowed down checked my memory on my Dakota digital spedo mem and 122 mph and that was in short order I had so much fun doing this that I turned around and did it again. I had my son in the car which works on the new rice burners with fart pipes. yes his face was white as a ghost and stated he could not believe the acceleration that a 50 year old car has..... let it cool off with a slow ride back home where we washed off the rubber pasted to the rear fenders of my 11000 paint job had fun for sure issues I still have ticks a bit, quiets down a lot when warmed up might play with the lifters again or just live with it. ditch the carb and put my efi back on after it gets back from warranty repairs. thanks a lot for all the help guys... honestly I am thankful |
#117
How are you liking the 2802 vs the 068 after driving it more?
Thread Tools | |
Display Modes | |
