Old 10-17-2020, 08:17 AM
Half-Inch Stud's Avatar
Originally Posted by Mill67 View Post
Another success story. Put an $11.00 carb in my golf cart 3 years ago, still going strong.
Hmmmm, THAT gives me an idea: a ChinaBay Propane carb for $11.
Old 10-17-2020, 08:29 AM
scott70's Avatar
scott70 scott70 is offline
Bought 15.00 cheap carb for a snowblower years ago...other than the bowl leaked which was a simple fix its still going.
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
Old 10-17-2020, 09:40 AM
David Jones's Avatar
My Stihl weed eater developed some carb related running ills and I bought one of the Chinese carb/fuel line kits. The fuel line was impossibly small, so I went back with some I had. The tank insert leaked. I never did overcome that. The engine did run and I think with a certain amount of tuning it would have been fine.
I had an epiphany while I was yanking on the starter rope one day. I’ve had shoulder surgery and probably will be having more. I don’t have to do this.
I bought a Milwaukee battery electric trimmer and edger. It’s probably more trimmer than the Stihl was, it’s lighter and cranking it is somewhat easier.
I gave the Stihl to my youngest and he put another Chinese carb kit on it and says it doesn’t leak now and runs fine.
Old 10-17-2020, 10:25 AM
I hear battery power chainsaws are the bomb...from our Louisiana PY guy
Old 10-17-2020, 05:23 PM
NeighborsComplaint's Avatar
I put one on a Toro snowblower that had a Tecumseh "Snow Command" motor. It ran just fine, no issues whatsoever for years.
Triple Black 1971 GTO
Old 10-17-2020, 07:27 PM
highway star's Avatar
highway star highway star is offline
The issue with most of these lil carbs is the diaphragms, harden with age. Just rebuilt our 1982 Weedeater's Walbro carb & now runs fine.
Old 10-21-2020, 12:29 PM
67ramair4's Avatar
67ramair4 67ramair4 is offline
Not had a problem with them, pressure washer, mower, and weed eaters! Work like a charm. on two cycle engines I only use full synthetic oil for the mix. The Ryobi blower runs too hot and seized the rings if full synthetic isn't used. It also has an offshore carb, starts and runs perfectly!
Old 10-21-2020, 03:34 PM
Mr Anonymous's Avatar
Mr Anonymous Mr Anonymous is offline
Small engines, 100% success so far. The chinese unit for my ford tractor? you know how that ended I assume.
Clutch Guys Matter
_______________________________________
53 Studebaker, 400P/th400/9"
64 F-85
72 4-4-2 Mondello's VO Twister II
84 Hurst/Olds #2449
87 Cutlass Salon
54 Olds 88 sedan
