Old 03-17-2009, 05:50 PM
lemans411's Avatar
lemans411 lemans411 is offline
my engine has solid mounts and a midplate. i dont expect it to move ever. the flex joints are just for heat expansion. but yes if i didnt have solid mounts i would have mounted it to the engine. i have to make a temporary mount for the dyno
-Rob
67 LE MANS in pieces...
68 gto
84 grand prix twin turbo 496 pontiac 25.3 cage
  #42
Old 03-17-2009, 05:51 PM
lemans411's Avatar
Info on the 83mm Garrett Turbo from the LS-1 Forums:
"I looked on here and did find a little info on it.
Compressor Wheel Inducer ( mm ) - 83mm
Compressor Wheel Exducer ( mm ) - 101mm
Turbine Wheel Inducer ( mm ) - 101mm
Turbine Wheel Exducer ( mm ) - 91mm
Turbine Inlet Flange - T-6
Turbine Housing Outlet - 5 Inch V-Band
My A/R is 1.08
We have the comp map for it I believe, its still available. Its an older TV84 unit and will flow around 93lbs/min. Not a good flowing wheel and spools slow. Also its an older flat back wheel which is hard to find any upgrades for as well."
(Is your Turbo Specs similar??)
Still 93 lbs per minute times 10.5 hp per lb of air per minute = 976 hp. Almost a 1000 hp at the engine for your set-up.
Tom Vaught
ps John Welter had a 106mm Turbo and went 6.80s in the quarter, how fast do you want to go 440GP69?
looks similar except mine has 1.32 a/r
-Rob
68 gto
  #43
Old 03-18-2009, 11:51 PM
lemans411's Avatar
Originally Posted by GOAT8U2 View Post
Cool another boosted Ponti. With an intercooler and E85 you'll have boost for days on conservative timing. What's your timing retard plans and WOT timing?
What head gaskets are you running and I'm sure you've got a wideband in a pillar to monitor everything right?
not real sure of timing . just gonna start low and work my way up. i have a programmable digital7 with boost retard so it will be very adjustable. i have cometic head gaskets and yes i have a wideband. i also have a msd knock alert for it .
-Rob
68 gto
  #44
Old 03-22-2009, 03:28 AM
lemans411's Avatar
fired the 535 today
http://www.youtube.com/watch?v=H-rOr0_jkiY
-Rob
68 gto
  #45
Old 03-22-2009, 04:35 AM
440GP69's Avatar
440GP69 440GP69 is offline
Awesome!!!
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines!
2006 silvy Z71 4X4,383 LS 600+hp NA
Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-}
  #46
Old 03-22-2009, 08:41 AM
ponjohn's Avatar
ponjohn ponjohn is offline
Very nice.
were you able to feel any volume of air out of the cold side?
  #47
Old 03-22-2009, 09:40 AM
Tom Vaught's Avatar
Boost Engineer
Hope you do NOT do something stupid like removing the oil feed line to the turbo to check for oil flow. A Guy I knew burned up a turbo as he read in Hugh MacInnis book to check for proper oil flow to the turbo by disconnecting the line. DO NOT DO THIS.
If you use a -4 line to the turbo you will have plenty of oil feeding the turbo. Make sure the oil drain always goes downward and enters the oil pan ABOVE the oil level.
Tom Vaught
  #48
Old 03-22-2009, 10:06 AM
ponjohn's Avatar
Tom Vaught
Seen a few installations where the oil drainback went into the fuel pump block-off plate.
  #49
Old 03-22-2009, 11:08 AM
rumair rumair is offline
very nice.
what's the cost of E85 compared to 110?
  #50
Old 03-22-2009, 01:39 PM
mysticmissle's Avatar
very nice and well packaged. I cant believe how well everything fit. great job
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
  #51
Old 03-22-2009, 03:30 PM
lemans411's Avatar
Originally Posted by ponjohn View Post
Very nice.
i could feel a steady flow of air at idle
-Rob
68 gto
  #52
Old 03-22-2009, 03:32 PM
lemans411's Avatar
Tom Vaught
we checked flow with my oil pump primer . and the drain goes into the timing cover right above the pan. had a fitting welded in the side
-Rob
68 gto
  #53
Old 03-22-2009, 03:34 PM
lemans411's Avatar
Originally Posted by rumair View Post
very nice.
i paid 1.45 for e85 110 is 7.00 a gallon even if i use twice as much e 85 its stil less than l half the cost of race gas
-Rob
68 gto
  #54
Old 05-15-2009, 06:03 PM
bankbook's Avatar
bankbook bankbook is offline
This is a great build. The process documenting it is great for those of us who are trying to do the same. Doing the same thing with a 106 mm Garrett into a 79 trans Am
Question: Wher are you taking the oil supply from on the IA2 block?
DOC'S TA
Turbo 535, CV 1 heads.
Built by Cerralli Competition Engines
Tenth Anniversary (Van Nuys) restored.
Tenth Anniversary Barn Find (Norwood)
Both 4 speeds!
  #55
Old 05-15-2009, 11:28 PM
marks73ta's Avatar
marks73ta marks73ta is offline
Rob, your intercooler. What size is the core? My new air to air I'm installing is 24Wx12Hx4deep. Is that about the same as yours? Looks like it in the vid. Was wondering if anyone might have felt it could be a restriction? I ran my turbo on a chassis dyno using a smallish air to water and got 887 hp at the wheels, 1064 at the motor. But it struggled at the strip. Ran 10.6 @ 128 laying down on the top end. That's why I'm putting in the air to air.
http://videos.streetfire.net/video/F...DAY_643621.htm
This is the vid. My TA's the last 4 runs. The 788 hp and 744 tq on the first run was really on 10 pounds. The next 2 were on 12 pounds and the last was 15 pounds. But I could feel the engine stop pulling at around 5800. That's where I stopped the pulls. I'm curious if the air to air seemed to run OK for you? One reason I'm asking is the lower HP vs the higher torque. Forgot to add th esound is out of sync with th evid on the last two runs. But you can hear the engine straining to rpm any more when it hits the top of the scale. Mark L
  #56
Old 05-16-2009, 12:11 PM
Tom Vaught's Avatar
Boost Engineer
When Dick Duclow first looked at making the IA-1 blocks, I asked him to put in a oil passage on the front of the block from the front main to the passenger side of the block (for a Vortech Supercharger oil feed line). You can also use this passage to read oil pressure at the front main on a race engine as the front main is the last one to get oil. Good oil pressure there, good oil flow at rpm.
The All Pontiac Block also has this oil passage.
Tom Vaught
  #57
Old 05-16-2009, 12:22 PM
lemans411's Avatar
yea sorry i missed that one that is where i feed the turbo from on mine
-Rob
68 gto
  #58
Old 05-16-2009, 06:56 PM
bankbook's Avatar
Just wanted to be sure.
DOC'S TA
Both 4 speeds!
  #59
Old 05-25-2009, 09:46 PM
79461W72 79461W72 is offline
Thumbs up
May I take your manifolds out for a night on the town?! EXCELLENT craftsmanship!
Vanderbilt Law C/O 2011!
  #60
Old 11-16-2009, 09:30 PM
ponjohn's Avatar
Did this ever make it to the dyno?
