Old 03-04-2017, 08:03 PM
TN68GTO's Avatar
TN68GTO TN68GTO is offline
Default Idle stop solenoid
After checking with Ames, Year One, OPGI and local parts I've come up empty on an idle stop solenoid. Anyone have any recommendations to where I can find one?
Jeramie
1968 GTO Convertible
1968 GTO Coupe, currently undergoing full frame off resto.
Old 03-04-2017, 08:56 PM
68bird400HO's Avatar
There are usually repops and originals on Ebay.
Old 03-04-2017, 09:27 PM
ponyakr's Avatar
ponyakr ponyakr is offline
Inline Tube sells a repop.
https://www.inlinetube.com/_p/prd14/...oid---inl14944
http://www.theautopartsdepot.com/product/5829914/
Here's a bracket for a '68 Q-jet, in case you don't have one,
http://www.ebay.com/itm/68-70-Pontia...-/200772036346
Old 03-08-2017, 01:03 PM
TN68GTO's Avatar
Originally Posted by ponyakr View Post
Both of those companies say it's discontinued. I'll keep searching.
Jeramie
Old 03-08-2017, 02:57 PM
Scott Thelander's Avatar
Default Hi
I have watched your posts and was hoping you would find one ...
I know they are are kinda hard to find..
I may have working spare ... I know I have one that does not work , I dont know if they can be repaired or not .... I have a stash box of old q jet stuff in an old edelbrock box under the bench ... I should have an empty table tomorrow after I get a few items ready for shipping tonite to spread the box out and do a bit of organizing...the box is packed full of alll carb and intake stuff..choke pulloffs
fittings original carb bolts and all that intakemisc...
Scott
Old 03-08-2017, 03:44 PM
DOC DOC is online now
Have you checked with Cliff Ruggles?
Old 03-08-2017, 05:17 PM
ponyakr's Avatar
If you just need one that is functional, you could find something similar and modify/rig it, to attach to the correct bracket.
But obviously, if you want numbers matching, that won't help at all.
Old 03-09-2017, 05:04 PM
TN68GTO's Avatar
Scott
Scott,
Since you have some spare Qjet parts would you happen to have the gas line fitting for the front of the carb? I was missing mine and had to settle for an aftermarket one. I'd really like to find an original in good shape. Let me know. I'm going to keep looking for my Idle Stop Solenoid, My engine swap has turned into a full frame off resto. I'm sure others can relate to that.
I'll let you know if I find one of the solenoids
Jeramie
Old 03-09-2017, 05:08 PM
TN68GTO's Avatar
I haven't checked with him yet. I think he's my next step. Thaks for the suggestion.
Jeramie
