Old 05-19-2024, 07:01 PM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
Default 67 LeMans Rear Gear Options
Hey guys.
Where can I find a break down of available options for a 67 LeMans?
Specifically looking for the rear end option info.
Joe
Old 05-19-2024, 09:07 PM
gtospieg gtospieg is offline
Options were: 2.56, 2.78, 2.93, 3.08, 3.23, 3.36, 3.55, 3.90, 4.33
Old 05-19-2024, 09:21 PM
ponchjoe's Avatar
Could you get a 326 2bbl with AC and an ST300 with a 3.55 limited slip?
Old 05-19-2024, 10:28 PM
Not with factory AC.
326 ST300 combo with factory AC should have a 2 something gearset at best.
Old 05-19-2024, 10:42 PM
My 1967 GTO with AC came with a 2.93 rear.
Old 05-20-2024, 07:23 AM
ponchjoe's Avatar
I figured 2.93 or 2.78 would’ve been correct
Old 05-20-2024, 08:39 PM
Certain cars and engine combos got specific gears from the factory. My 67 with AC also came factory with 2.93's. It was my understanding you could order any available gear that you wanted.
Old 05-20-2024, 09:29 PM
ponchjoe's Avatar
Thanks guys
I found the code on the tube tonight. It started out as a 2.93 single track and has been upgraded to what appears to be 3.23 or 3.55 LS
Old 05-21-2024, 05:59 AM
Jeff Hamlin's Avatar
Default FWIW
PMD Cat list gears ;
Standard 326 AT w/AC 2:78 with No S.O. gears listed.
HO 326 AT w/AC 3:23 with S.O. gears of 3:08 & 3:36
Name:	67 326 gear x.jpg
ID:	634055   Click image for larger version
Name:	67 326 gear.jpg
ID:	634056   Click image for larger version
Name:	67 326 gear 2.jpg
Old 05-21-2024, 08:12 AM
ponchjoe's Avatar
That’s strange. It is a WC code axle and appears to be original to the car. Wallace has that listed as a ‘67 single track 2.93. The car is a 326 2bbl car originally with an ST300
