Old 03-07-2021, 12:14 PM
chrisp chrisp is offline
Default Steel fan shroud
64 uses the small tapered & upper hose shroud , what would the larger tapered one be for 66/67 ?
Name:	Fan shroud deep.jpg
ID:	562245   Click image for larger version
Name:	Fan shroud shallow.jpg
Old 03-07-2021, 02:03 PM
gtopont gtopont is offline
Smile 64 fan shroud
you can look on the ames/performance years catalog and see the difference originals are metal they have exact copies that are plastic...
Old 03-08-2021, 08:38 AM
Underestood as they list 64-67 the same but are not . i am aware of the 2 different heights . Just wanting to identify the one in my picture that is not tapered as much as the other one. I am thinking 63/64 fullsize blue picture . 64/65 red picture.
Old 03-08-2021, 11:34 AM
pfilean's Avatar
pfilean pfilean is offline
Yes the blue picture does look like the 61-62 big car. The 61-62 had the bolting flange at about 2 inches wide each side. 63-64 were only about 1 inch wide each side. Those two can be interchanged with a bit of good metal work to either widen or narrow as needed.
