Old 01-26-2022, 01:36 AM
GoreMaker GoreMaker is offline
Default Color of Turn Signal Lights on Dash
My old '78 Trans Am had green flashing turn signal arrows on the dash. My new '77 has red ones. Which is correct? Is it a function of the bulb color, or does the lens determine the color?
Honestly, the red looks really angry to me I find it a bit jarring compared to the typical green turn signals.
Old 01-26-2022, 08:08 AM
77 Canamman's Avatar
Green is original. The green colored filters were either located on the dash bezel or the cluster depending on the year.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
The Following User Says Thank You to 77 Canamman For This Useful Post:
Old 01-26-2022, 08:42 AM
So somebody went to the trouble of changing the filter colors in the bezel? That seems so odd for a car that was mostly kept meticulously original
Old 01-26-2022, 08:47 AM
TAKerry TAKerry is offline
The filters look like an old green plastic bingo chip. I believe there should be a small diameter cardboard tube behind to direct the light.
Old 01-26-2022, 10:35 AM
bhill86's Avatar
bhill86 bhill86 is offline
Didn’t TATA and/or pace cars have red? I feel like I just saw a member somewhere post his cluster from a pace car and it had red lenses.
1977 Trans Am 400/4speed (swap)
Brian
Old 01-26-2022, 10:41 AM
bhill86's Avatar
Found it
https://forums.maxperformanceinc.com...47#post6313147
Brian
Old 01-26-2022, 11:14 AM
78w72 78w72 is offline
all pace cars & tata's had green turn signals. the earlier firebirds & t/a's used cardboard tubes with a green filter cap & later years (78?-81) used a green lens glued to the bezel. no turn signals were red from the factory.
the red paint on the lens over the turn signals in that link posted is not factory from any 2nd gen cars i have seen. all red gauges were painted a bright fluorescent red inside the housings to create the red back light.
Old 01-26-2022, 12:50 PM
bhill86's Avatar
Gotcha. I wasn’t sure
Brian
Old 01-26-2022, 01:13 PM
Now I'm gonna have to take my bezel off and check what's going on because this seems really weird to me. I have no clue why my turn signals would be red.
Old 01-26-2022, 01:41 PM
someone painted the lens or installed red bulbs...
Old 01-26-2022, 01:48 PM
Yeah what I mean is I have no idea why someone who's trying so hard to keep the car original would go and do that. It seems bizarre. Upon closer inspection, the lenses look red.
Old 01-26-2022, 02:12 PM
hard to say why someone would do that, people did all kinds of strange things to these cars over the years.
let us know what you find when removing the bezel.
Old 01-29-2022, 09:21 PM
Took the gauge cluster out today. To my eye, this looks OEM. The red tint is printed on acetate in precisely the right shape to cover the turn signal opening, and they look like they were applied there from the factory. It's really obvious on this car spotting the differences between stuff that was done at the factory and later work that was done by previous owners, and this matches all the OEM stuff really well. There's a CHANCE that it was modified, because one of the backlight bulbs is missing altogether and its spot very obviously had a bulb in it in the past, so clearly this cluster has been pulled before. But the cluster appears to be original to the car. So I guess there were some 1977 Trans Ams built with red turn signals in the dash. This one was built in December 1976.
Old 01-29-2022, 10:03 PM
those look nice. i hate to be a downer on this, but i dont think that was a factory thing. i have never seen or heard of a factory 1977 or any other 2nd gen year firebird or trans am having red turn signals, i could be wrong since ive obviously never seen every firebird out there, would be curious if anyone else here has seen or heard of this. if you ever see another one like that please post a pic. my guess is someone really wanted red turn signals & they cut out the red pieces to fit the lens.
i wonder if there is or was some regulation or law that turn signals are green since other more important warning lights are red? other car makes are green too & if any firebird was going to get red turn signals it would have been the 79 10th anniv & 80/81 pace cars that had the red gauges & radio LEDs. just a guess.
Old 01-29-2022, 10:14 PM
That's the thing though, if it was a cutout I could see it being a modification. But it's not, it looks like something that was stamped at a factory. Honestly, I'd kinda prefer if they were green but one of my goals with this car is to keep its appearance mostly original, and this is one of those bizarre details that really fascinates me. I'm still kinda perplexed by it.
Old 01-29-2022, 10:23 PM
i cant say for sure, just going with what ive seen on these cars over a long time of owning & learning about them but who knows, maybe it was an aftermarket company in the 80s that made them for some cars? i know its not a factory option to order anywhere i have seen. keep looking into it.
Old 01-30-2022, 05:42 AM
Mike Davis's Avatar
The link posted is my cluster that is in my 80 Y84. The original lens was painted red in that spot. Not really sure why on a 31K mile car that was mostly original. I bought a lens off a guy at a swap meet and the signal area was painted red as well.
I have had about 6 T/A's over the years and they were all green.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 01-30-2022, 08:57 PM
Mystery solved! The guy who owned it for 30+ years until 2014 was the one who made them red because the green filters had faded to practically clear and he liked the look of the red. So it's not factory-original. Took me a while to track the guy down.
Old 01-31-2022, 09:06 AM
There ya go. No matter how original a car is, we need to keep in mind these that a lot of stuff can happen over 40 or 50yrs. Even if its changing the turn signal colour!
The Following User Says Thank You to TAKerry For This Useful Post:
