Old 02-09-2022, 01:26 PM
jonra3 jonra3 is offline
Default GM part Number for 79-81 WS6 steering gear box
Hi would anybody have access to a 79-81 GM parts catalogue? I'm looking for the part number for the WS6 steering gear box.
Any help is greatly appreciated.
Jon
Old 02-09-2022, 02:21 PM
nUcLeArEnVoY's Avatar
nUcLeArEnVoY nUcLeArEnVoY is offline
7848140 for 1980 and 1981. 1979 is iffy, every listing for 78 and 79 in the catalog is for non-WS6.
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop
Old 02-10-2022, 02:07 AM
Carl S Carl S is offline
7833312 for 78-79 WS6.
Old 02-10-2022, 09:31 AM
This is from John Witzke article - Quicker steering ratio, 14:1 straight ratio instead of variable ratio for standard Trans Am.
Part # 7829773
Not sure if that is the order part # or the casting #?
Old 02-10-2022, 03:10 PM
Thanks for the responses, nUcLeArEnVoY what parts book did you get that number from?
That is the one I have also, new in the box, I bought it in December of 90, as I recall it was changed from 7829773 to 7848140 according to the Pontiac part books they had at the dealership at the time. I plan on using it on my restoration. 7833312 then goes to 7829773 or visa versa? I'm trying to check the history of the number with out 79-81 parts book.
Thanks for the help.
Jon
Old 02-10-2022, 03:43 PM
That box require adapters that go from flare to metric o-ring?
Clay
Old 02-11-2022, 01:38 PM
I'm using coupling flange # 7826542 gr 6.525 that is a metric one. Is that what you are are asking?
Does any body know how to tell the difference between WS6 gear box and a standard one?
Jon
Old 02-11-2022, 01:51 PM
77 Canamman's Avatar
Straight ratio firm feel vs. variable ratio
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 02-11-2022, 02:05 PM
Sorry, I should of said the gear box is not on the car. Still new in the box. I just want to make sure I have a WS6 gear box.
Old 02-12-2022, 10:34 PM
Jon
My reference was the 1976-1981 parts catalog. Are you aiming for concourse quality? A replacement steering gearbox wouldn't deduct points at most shows other than the most discerning. But hey, if you have an original like you say you do, then by all means, use it. Remans are hit-or-miss.
