Pontiac - Boost Turbo, supercharged, Nitrous, EFI & other Power Adders discussed here. |
Is it worth upgrading to RAM AIR IV Aluminum Heads?
Thinking about upgrading to Edelbrock RAM AIR IV Aluminum Heads this winter.
My set up currently is 455 bored .30 over, TRW Forged Pistons, 4X Heads with Comp cam ram air V and Nodular Crankshaft 9799103 Who is running 455 with aluminum heads? How much horse power would I be gaining? Can I run on pump gas 87 or 93? Thanks in Advance for feedback
charlestown chiefs t-shirts |
Stock RA-IV cast iron heads flow 230 cfm at 25" of Test Pressure.
Edelbrock Aluminum RA-IV Heads will flow 280 cfm at 25" of test pressure STOCK and are lighter. 50 cfm increase per port does make a difference on an engine. Tom V.
"Engineers do stuff for reasons" Tom Vaught Despite small distractions, there are those who will go Forward, Learning, Sharing Knowledge, Doing what they can to help others move forward. Last edited by Tom Vaught; 10-18-2019 at 05:55 PM. |
Thanks for reply
Thanks for reply. Any idea of about what the compression would be? And how it would run on 87 octane? Horsepower increase?
Horse power and 87 octane are maybe the two words I haven't read in 20 years on any performance car forum. You'll see a 21% increase in air flow so if you're air fuel ratio is the same you'll notice a power increase.
I wouldn't bother running anything lower than 92 or 93 if you're looking to make power, have a heavy vehicle and throw some timing in it (36 etc). You have more to lose then 30 cents per gallon saved.
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Intake & Rails, PTC 10" 0 Stat, Ricks Hot Rod SS Gas Tank, Magna 4303, Aerom EFI Reg, Aerospace Front & Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, Powersteering.com Pump & 12:1 Box, QA1 Front Arms & Viking Berz CO + Rear Shocks, Hella UP28 Vac Pump |
Haha, Not trying to be cheapskate at all. Current set up runs great on 87. Was just curious, I'm a fairly stock guy and my first build, and want to gain some more power and performance.
My Half AN Injun..... |
No, any ideas? Just looking for fast street car
Put this in the street section if you want more input than you can handle...
thanks will put n street section thanks
Thread Tools | |
Display Modes | |
