Old 10-27-2019, 09:55 AM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Default Turbonetics Exhaust Housings
I have a set of Turbonetics HPR-88 F1-89 .96 A/R on the Raven, looking to change the exhaust housing to either of the following. Turbonetics doesn't have any available. Looking for another source, any suggestions?
I'm not seeing much of a change in power increase going from low 20lb to ~30lb boost.
1.23 AR P#21786 Preferred
1.39 AR P#21787
Thanks,
Name:	Screenshot 2019-10-27 09.49.38.jpg
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 10-27-2019, 01:57 PM
Tom Vaught's Avatar
Boost Engineer
Talk to Brad Lewis at Turbonetics tomorrow and see if Harry (former owner of Precision) can have his guys send you a couple of 1.23 AR housings from their inventory IF you pay for them or swap yours for the larger ones. They are both working for the same company these days so it might be easier than you think.
Tom V. .
Old 10-27-2019, 03:42 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Is it blowing through the convertor with the increased power?
Old 10-27-2019, 04:47 PM
RAIV-Z's Avatar
Originally Posted by ponjohn View Post
Is it blowing through the converter with the increased power?
Not since I filled the trans with John Deere hydraulic fluid. I will run out of gear in the quarter though.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
