Some of what im working on
Working on a couple things at once. A 462 for my street strip can and my 525 wide port engine. The 462 is 13 to 1 with standard port heads. Solid roller cam with a victor intake. 1050 carb. Adding a plate system. The 525 intake just got finished. Ia2 aluminum block based. It's been kind of stagnant here so just trying to break up the silence.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
Few more pics
The Following User Says Thank You to chiefbigb For This Useful Post: | ||
WOW!!!....very very nice...
Those main bearings are interesting. What did they begin life as? (What Brand?) Thanks.
Brian
Boobs & bacon |
The Following User Says Thank You to BADDTA For This Useful Post: | ||
Oh, I see! I saw the aluminum look and assumed it was the bearing. Then I realized an aluminum block, DUH. So is the bearing then fed through a series of holes in the bearing or an elongated slot such as the FM bearings? Looks like a fancy set-up for sure. No doubt the Pontiac oiling system needs help in this area.
Different ways to attack the problem. |
Did you modify the bearings in any way to fit the mod ?
You have some nice looking cars and the rest BTW. |
Read post 13
I dont have any bearing pics. This modification is something I came up with. Jeff Kinsler had some pics on here of what BES does and I changed it into what makes sense to me. 3 direct pressure points where bearing clearance is tightest vs one where there is a 90 deg change.
Hellyeah
Nobody likes a bragger lol. Looks great and love that hood
That thing is bitchin dude!! My son and I r starting his aluminum IAII build this week also.
Brian
Boobs & bacon |
Nice! Hit us with some details on the builds unless they are grudge race deals.
I still want that car Brain..
Try motivation instead of want. I bet you get a sore back sleeping on that rock hard convex mattress.
That's somewhat of a ls main saddle I'm trying. Going to drill 2 holes in the bearing twards the end of the slots. The 525 is set up for spray. Shoukd be around 1100hp on a 300 hit. The car is a 70 camaro s and w mild steel chassis that im making into a 70 trans am. Race weight under 2400. Thanks for the kind compliments.
Camaro conversion pic
Keep us in the loop on that car as it TRANSforms |
Insanely cool car and really nice shop
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
