OHC-6 TECH Over Head Cam projects, questions and advice.
Old 08-30-2022, 09:20 AM
sprintbird sprintbird is offline
Originally Posted by Doctor john View Post
Great work! What are the part numbers for the accessory housing bearings and seals? How did you find them?
I have the seal and bearing in stock if you need them.
Rob
  #82
Old 09-05-2022, 05:40 PM
Jeff Hamlin's Avatar
Thumbs up Nearing the end...
...All machine work complete.
Getting ready to send out some rockers for refacing and then it's all on me.
ID:	597919   Click image for larger version
ID:	597920   Click image for larger version
Name:	SPRINT 34 (1).jpg
ID:	597921   Click image for larger version
Name:	SPRINT 34 (2).jpg
  #83
Old 09-25-2022, 07:19 PM
Default Rockers are back and look great.
Now it's down to bolting on the Manifolds, loading the Cam, and firing it.
Name:	SPRINT 36 (1).jpg
ID:	599341   Click image for larger version
Name:	SPRINT 36 (5).jpg
ID:	599342   Click image for larger version
Name:	SPRINT 36 (8).jpg
ID:	599343   Click image for larger version
Name:	SPRINT 39 (2).jpg
ID:	599344   Click image for larger version
Name:	SPRINT 40 (1).jpg
  #84
Old 10-20-2022, 07:04 AM
Thumbs up CAM CHECK
OK, now we're getting down to the end. I got sidetracked (again) with planning a run stand but back to the build.
Looked over and checked all specs, if all goes well I'll load the cam into its house and move along with this engine.
Name:	SPRINT 36 (11).jpg
ID:	600803   Click image for larger version
Name:	SPRINT 36 (12).jpg
ID:	600804   Click image for larger version
Name:	SPRINT 36 (13).jpg
ID:	600805   Click image for larger version
Name:	SPRINT 36 (13)a.jpg
ID:	600806   Click image for larger version
Name:	SPRINT 36 (13)b.jpg
  #85
Old 10-24-2022, 06:05 AM
Thumbs up CAM is in...
Finally.
Name:	SPRINT 36 (13)c.jpg
ID:	601044   Click image for larger version
Name:	SPRINT 36 (13)d.jpg
ID:	601045   Click image for larger version
Name:	SPRINT 36 (13)f.jpg
ID:	601046   Click image for larger version
Name:	SPRINT 36 (13)h.jpg
ID:	601047   Click image for larger version
Name:	SPRINT 36 (13)i.jpg
  #86
Old 10-31-2022, 05:57 AM
Thumbs up GIVE ME FUEL , GIVE ME FIRE!
Well, that didn't take long now, did it?
Hope to make a small run stand of sorts and hopefully,
I can fire her up before Christmas
  #87
Old 10-31-2022, 11:47 AM
wbnapier wbnapier is offline
Congrats! Looks great!
1965 Pontiac GTO
455/469 w/ #48 Heads, '65 Tri-Power
9.25:1 CR
Stump Puller Cam
Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00
3.55 Rear Differential
Front: 225/60R15 Height: 25.6"
Rear: 275/60R15 Height: 28"
  #88
Old 11-20-2022, 08:15 AM
Thumbs up OK I think I have a plan to run it...
A good friend had some old engine carts so I took one and made a few mods and think it will work.
Name:	ENGINE CART 1B.jpg
ID:	602351   Click image for larger version
Name:	1966 OHC 4BC BUILD 1 (304).jpg
ID:	602352   Click image for larger version
Name:	1966 OHC 4BC BUILD 1 (306).jpg
ID:	602353   Click image for larger version
Name:	1966 OHC 4BC BUILD 1 (305).jpg
  #89
Old 11-20-2022, 08:54 AM
Doctor john Doctor john is offline
Jeff, how and where did you secure the engine to lift it safely?
  #90
Old 11-20-2022, 10:19 AM
John,
I used two Engine Hoist Brackets for the V8 and on the PS, used the bolt hole in the head for the fuel line clip, and on the DS the hole for the vac line bolt.
More than adequate.
I found the best lift point on the chain to be just forward of the carb.
  #91
Old 11-20-2022, 10:23 AM
Old 12-17-2022, 05:38 PM
Default ONE FORWARD, TWO BACK AS THEY SAY.
What a day, Decided to jump back into this build since I had my Flywheel all dolled up.
The first issue was the rails interfered with the installation.
No big deal, so I break out the hoist lift the engine and move it forward a bit.
With the flywheel now installed I grabbed the starter and yup rails and leg interfered with install
Hoist it up again and change over to a Dolly with blocks.
How I can install the starter, But wait still a bit close with the blocking
Great, so I hoist this b!tch again and reset the engine one more time
OK enough playing around, I hook up a battery, remote start trigger, and Oil Gauge, and attempt to check the oil PSI.
Cranking and cranking but still no oil
Remove the gauge fitting and crank some more no oil comes out
I then pull the distributor and galley plug on the head, made a drive tool for my drill, and started spinning the pump.
You guessed it, friggen oil everywhere
Clean Up Isle 5!
HOUSTON WE HAVE PRESSURE!
I had to stop at this point and will regroup in an attempt to fire it up.
Too much fun
Name:	1966 OHC 4BC BUILD 1 (315).jpg
ID:	603716   Click image for larger version
Name:	1966 OHC 4BC BUILD 1 (312).jpg
ID:	603717   Click image for larger version
Name:	1966 OHC 4BC BUILD 1 (313).jpg
  #93
Old 12-22-2022, 07:25 AM
Red face So close.
Was really trying to get this up and running before Christmas but Mother Nature threw us a curve
Going to make a rack for a Radiator and then we should be good to go.
CLICK ON IMAGE FOR VID;
[url=https://flic.kr/p/2o6uomP]
  #94
Old 12-22-2022, 07:31 AM
Exclamation STARTER MODIFICATION
Also just for grins, I decided to use a Chebby Starter rather than the Rebuilt OE I have for this build.
I just wanted to show how simple it is to clearance the Drive Housing / Cone to make it work.
CLICK IMAGE FOR VID;
IMG_4570 by [url=https://www.flickr.com/photos/149936083@N07/]
  #95
Old 01-04-2023, 08:07 PM
Default CRUDE...
...BUT WORKS
  #96
Old 01-06-2023, 07:38 AM
Red face
Fuel? CHECK.
Spark? CHECK.
Contact, crank crank crank, sputter sputter WTH.
Timing alignment? DOUBLE CHECK.
Contact, crank crank crank...
Hmmm, what could it be?
OMG
STAND BY
Name:	1966 OHC 4BC BUILD 1 (265).jpg
  #97
Old 01-06-2023, 11:22 AM
Jeff is that a 69 Cam Sprocket I see? If so your cam is out of time by 180 degrees, it should be pointed down not up like the 66-68 Sprockets.
  #98
Old 01-06-2023, 09:19 PM
BINGO!
I don't know how I looked right over it
  #99
Old 01-06-2023, 10:42 PM
Bill Hanlon's Avatar
I'm no OHC expert, but won't turning the crankshaft 1 turn fix this problem? May have to re-time the distributor or move the plug wires at the distributor 3 positions left or right depending on your political leanings.
  #100
Old 01-07-2023, 07:25 AM
Thumbs up
Correct,
knowing I had a stack of sprockets I went digging and found what I need.
And if anyone needs a '69 Sprocket LMK, for some reason I have several.
Name:	CAM SPROCK 1.jpg
ID:	604726   Click image for larger version
Name:	CAM SPROCK 2.jpg
ID:	604727   Click image for larger version
Name:	CAM SPROCK 2X.jpg
ID:	604728   Click image for larger version
Name:	CAM SPROCK x.jpg
