Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 07-01-2020, 04:49 PM
jonathonar89 jonathonar89 is offline
Default Mild Built 1979 W72 Pontiac 400
After a personal deal falling through, I have decided to post my Pontiac 400 on the public forum. This is a mildly built combination but it makes awesome power. It actually makes more power than my stock LS1...no joke there. I previously had an aftermarket intake on but I have been in the process of putting a stock intake back on. That is why the intake and valley pan look ugly. I have roughly 7k miles on this combination....not that much run time. Great for anyone trying to restore a '79 400 W72 Firebird or someone simply wanting a strong street engine. I did this build in about 2010 and I roughly put $4k in this setup at the time. This will be intake to oil pan (no carb or ignition) with front accessories.
Also, this is from a non-air conditioning car so it has the metal hose bracket rather than the a/c components. Another difference over the a/c cars is it has a straight fan without a fan clutch.
Bottom end...
1979 PWH Code block
Block deck milled
+.030" KB Forged Icon Pistons
ARP rod bolts on stock rods
Top end...
6X-4 heads milled to 87cc combustion chambers
Converted to screw-in rocker studs with locks on the stock rocker arms
Lunati Voodoo series cam shaft
$2500
Untitled by Jonathon Randolph, on Flickr
Old 07-02-2020, 10:06 AM
78w72 78w72 is offline
curious why you say converted to screw in rocker studs, 6x heads come stock with them.
good luck with sale.
Old 07-02-2020, 01:42 PM
Hello,
I basically said it has screw-in poly locks. You forgot the, “with....”
Thanks,
Jon
Old 07-02-2020, 01:53 PM
ok just curious.. but technically its worded that they were converted to screw in studs with locks. sorry for the confusion.
Old 07-14-2020, 09:46 PM
Still available.
I popped off the valley cover to show it still looks brand new inside and then did some detailing on the outside. Again, this is a well built engine.
Also, I forgot to mention in my initial post that it has an aluminum Flow Kooler water pump.
Old 07-19-2020, 11:19 AM
MrdrGrndM MrdrGrndM is offline
Would you swap for a 350 and a 455? Both needing rebuild but including #62 heads
Old 07-19-2020, 11:23 AM
I’m ok, thank you for offering though!
Old 07-25-2020, 05:04 AM
Sold!
