Old 12-27-1999, 04:57 PM
badguy badguy is offline
somehow they built a gto without safety trac. what is the best and most economical way to add posi trac to a 67 gto? thanks in advance.
Old 12-27-1999, 07:06 PM
Todd Todd is offline
[This message has been edited by Todd (edited 07-18-2000).]
Old 12-28-1999, 11:19 AM
thanks todd. which of the after market gear swaps do you recommend? and yes it is the factory stock rear end and i would like to keep it that way. i really like the 'set up' that i have now for what i do with my gto. currently have the 3:55 ratio and it seems to work well on the freeway and 1/4 mile run however it is tempting to go with the 4:11 but i hate a high screaming motor on the freeway. thanks again todd.
Old 01-02-2000, 12:46 PM
try contacting lock-rite or one of their dealers . they produce a locker style rear diff that replaces the spider gears in your open carrier. this eliminates the setup unless you are changing the gear ratio. i know of two of these units in 4x4's and they work well.the only drawback is that there is a clicking noise when turning. this is similar to a ford detroit locker unit. hope this helps. mnixon
former." --Albert Einstein
- Winston Churchill
