Old 07-06-2010, 08:41 PM
Birdguy's Avatar
Birdguy Birdguy is offline
Default Trunk lid torsion rods
I just spent 2 1/2 hours in the trunk of my 'Bird reinstalling the trunk lid torsion rods. The next time I want to have that much fun I'll strip naked and roll around in an acre of poison ivy. If anyone needs a how-to on this procedure, I'll be happy to do so after my therapy is completed.
Old 07-06-2010, 09:08 PM
Cammer-6 Cammer-6 is offline
takes about 2 minutes each.
Use a small long box end wrench to control the ends
I think its 8mm or 5/16.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 07-06-2010, 09:50 PM
Birdguy's Avatar
Like most everything else on this project, this was a new experience for me. To tell the truth, a goodly part of the time was spent trying to get into position in the trunk (been having major back problems lately) and planning my attack. My neighbor has a '67 Camaro convertible, so I went down to look as his torsion rods to confirm my memory on how they are installed. After getting the small end of the rod into position in the hinge I was left with a 270 degree reverse bend on the opposite end to get the rod into the notch and the end hooked onto the top position.
I tried using a box wrench, but that didn't work very well, so I found success using a 6" extension with a small deep-well socket. After that it was a matter of muscling it around to get it seated and then hooked.
I guess it's the results that matter, and the lid swings open like a champ now.
Old 07-08-2010, 02:38 PM
Bill H's Avatar
Bill H Bill H is offline
Default Tool
I made this tool and used it, works very well.
ID:	211222   Click image for larger version
67 GTO HT
1968 400 Engine YE
TH-400
#13 Heads -J069
Q'Jet .
8.2 Eaton Posi/3:55
Old 03-23-2020, 10:20 AM
gpguy gpguy is offline
Default Torsion Rod Tool
Thanks to all especially "Bill H" for posting the torsion rod installation tool drawing and picture. It looks just like the picture in my 1972 Fisher Body Service Manual and lists it as tool "J-21412" used for A & X Body. I made one and cant wait to try it. I used 3/8" thick x 1" bar stock I had around but it probably would work with 1/4" or even thinner also. This is for a 71 GP and manual does not list G Body separate in this case but looks like the A body setup.. The manual does not say which rod goes to which side but I do have blue paint markings on different ends of each rod. The rods are made different. I'll have to look at my 72 to see if I can figure it out. but being installed and under tension I'm not sure I can determine that yet. Anyone have an idea as to which way they go?
GP.Style
70 GP SJ White/Blk/Blk
71 SJ 455 4 spd Blk 3X
72 J Sundance Orange/Wht/Wht
Old 03-31-2020, 10:47 AM
In case anyone else needs this info, I found that the small bent "tabs" on the "L" ends (adjustable ends) face the front of car on both rods on my original condition 72 GP. I think I had read on another post this was the case for that example also. This being the case they can only go in one way. Not sure why the two rods are bent different as compared when uninstalled. Perhaps just to get the proper tension range. The tool works great and makes this a breeze.
GP.Style
