Remove and install honeycomb trim rings
What’s the best way without damaging trim rings? Thanks
The first betrayal is what they did to you. The second betrayal is what you do to yourself. 1967 Firebird 400 convertible 4 speed #'s matching 2002 SOM Trans Am WS6 Convertible 6 speed bone stock 1970 GTO convertible auto #'s matching |
I remove the tire, lay flat on the ground, deflate the tire so I can get behind the clips easier, and they pop right off. Also much easier to reinstall this way as well.
This is what I have done as well...you maybe able to do it without deflating but I had to at least take the tires off the car and compress in a couple of different area's to get them clipped. If you have NOS trim rings its easier than the repops.
JIM |
