Old 05-30-2023, 11:44 PM
Default Reverse lites...74 TA
Does anyone know the wire color or have a schematic of the reverse wiring in the trunk handy?
Thanks!
Old 06-04-2023, 10:24 AM
chuckies76ta's Avatar
I looked in my 1973 manual which should be the same as 74 and it shows color 18 Lt Green as reverse lights. The black being the ground
Old 06-04-2023, 10:54 AM
Thats what I found on the internets as well yet the turn signal looks the same shade afaict.
50 years of shenanigans hard to tell what is what.
Sent from my Surface Duo using Tapatalk
Old 06-04-2023, 02:27 PM
Sirrotica's Avatar
Going from memory, having to straighten out T/A wiring that was hacked up, I recall the B/U lights were much lighter green insulation than the right turn signal. The easiest way is to test with a test light while having the right turn signal engaged it will blink. Likewise with engaging the B/U light switch. That's how I'd sort out which was which.....
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 06-04-2023, 03:15 PM
The turn is working but nothing coming from the greenish wire.
The trouble must be upstream...
Old 06-04-2023, 04:41 PM
Sirrotica's Avatar
B/U lights are usually fused, then they go through the neutral safety/ B/U light combination switch, again going from memory, not a schematic.
Sometimes the neutral safety switch needs adjusted on the lower steering column.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 06-04-2023, 05:00 PM
Neutral safety definitely doesn't work... Sigh, typical monkey business
Old 06-05-2023, 09:26 AM
sp4spd's Avatar
sp4spd sp4spd is offline
Definitely light green wire to back up lamp.
All the grounds tight?
Scott
74 Firebird Formula 400 4speed
70 Buick GS455 4 speed
